2.2.2.2 The #declare and #local Directives
Identifiers may be declared and later referenced to make scene files more readable and to parameterize scenes so
that changing a single declaration changes many values. There are several built-in identifiers which POV-Ray declares
for you. See section "Float Expressions: Built-in Variables"
and "Built-in Vector Identifiers" for details.
2.2.2.2.1 Declaring identifiers
An identifier is declared as follows.
DECLARATION:
#declare IDENTIFIER = RVALUE |
#local IDENTIFIER = RVALUE
RVALUE:
FLOAT; | VECTOR; | COLOR; | STRING | OBJECT | TEXTURE |
PIGMENT | NORMAL | FINISH | INTERIOR | MEDIA | DENSITY |
COLOR_MAP | PIGMENT_MAP | SLOPE_MAP | NORMAL_MAP |
DENSITY_MAP | CAMERA | LIGHT_SOURCE | FOG | RAINBOW |
SKY_SPHERE | TRANSFORM
Where IDENTIFIER is the name of the identifier up to 40 characters long and RVALUE is any of the
listed items. They are called that because they are values that can appear to the right of the equals sign.
The syntax for each is in the corresponding section of this language reference. Here are some examples.
#declare Rows = 5;
#declare Count = Count+1;
#local Here = <1,2,3>;
#declare White = rgb <1,1,1>;
#declare Cyan = color blue 1.0 green 1.0;
#declare Font_Name = "ariel.ttf"
#declare Rod = cylinder {-5*x,5*x,1}
#declare Ring = torus {5,1}
#local Checks = pigment { checker White, Cyan }
object{ Rod scale y*5 } // not "cylinder { Rod }"
object {
Ring
pigment { Checks scale 0.5 }
transform Skew
Note: that there should be a semi-colon after the expression in all float, vector and
color identifier declarations. This semi-colon is introduced in POV-Ray version 3.1. If omitted, it generates a
warning and some macros may not work properly. Semicolons after other declarations are optional.
Declarations, like most language directives, can appear almost anywhere in the file - even within other statements.
For example:
#declare Here=<1,2,3>;
#declare Count=0; // initialize Count
union {
object { Rod translate Here*Count }
#declare Count=Count+1; // re-declare inside union
As this example shows, you can re-declare an identifier and may use previously declared values in that
re-declaration.
Note: object identifiers use the generic wrapper statement object{ ... }.
You do not need to know what kind of object it is.
Declarations may be nested inside each other within limits. In the example in the previous section you could
declare the entire union as a object. However for technical reasons there are instances where you may not use any
language directive inside the declaration of floats, vectors or color expressions. Although these limits have been
loosened somewhat since POV-Ray 3.1, they still exist.
Identifiers declared within #macro ... #end
blocks are not created at the time the macro is defined. They are only created at the time the macro is actually
invoked. Like all other items inside such a #macro definition, they are ignored when the macro is defined.
2.2.2.2.2 #declare vs. #local
Identifiers may be declared either global using #declare
or local using the #local directive.
Those created by the #declare directive are permanent in duration and global in scope. Once created,
they are available throughout the scene and they are not released until all parsing is complete or until they are
specifically released using #undef. See "Destroying
Identifiers".
Those created by the #local directive are temporary in duration and local in scope. They temporarily
override any identifiers with the same name. See "Identifier Name
Collisions".
If #local is used inside a #macro then the identifier is local to that macro. When the
macro is invoked and the #local directive is parsed, the identifier is created. It persists until the #end
directive of the macro is reached. At the #end directive, the identifier is destroyed. Subsequent
invocations of the macro create totally new identifiers.
Use of #local within an include file but not in a macro, also creates a temporary identifier that is
local to that include file. When the include file is included and the #local directive is parsed, the
identifier is created. It persists until the end of the include file is reached. At the end of file the identifier is
destroyed. Subsequent inclusions of the file create totally new identifiers.
Use of #local in the main scene file (not in an include file and not in a macro) is identical to #declare.
For clarity sake you should not use #local in a main file except in a macro.
There is currently no way to create permanent, yet local identifiers in POV-Ray.
Local identifiers may be specifically released early using #undef
but in general there is no need to do so. See "Destroying Identifiers".
2.2.2.2.3 Identifier Name Collisions
Local identifiers may have the same names as previously declared identifiers. In this instance, the most recent,
most local identifier takes precedence. Upon entering an include file or invoking a macro, a new symbol table is
created. When referencing identifiers, the most recently created symbol table is searched first, then the next most
recent and so on back to the global table of the main scene file. As each macro or include file is exited, its table
and identifiers are destroyed. Parameters passed by value reside in the same symbol table as the one used for
identifiers local to the macro.
The rules for duplicate identifiers may seem complicated when multiple-nested includes and macros are involved, but
in actual practice the results are generally what you intended.
Consider this example: You have a main scene file called myscene.pov and it contains
#declare A = 123;
#declare B = rgb<1,2,3>;
#declare C = 0;
#include "myinc.inc"
Inside the include file you invoke a macro called MyMacro(J,K,L). It is not important where
MyMacro is defined as long as it is defined before it is invoked. In this example, it is important that the
macro is invoked from within myinc.inc.
The identifiers A, B, and C are generally available at all levels. If
either myinc.inc or MyMacro contain a line such as #declare C=C+1; then the
value C is changed everywhere as you might expect.
Now suppose inside myinc.inc you do...
#local A = 546;
The main version of A is hidden and a new A is created. This new A is also
available inside MyMacro because MyMacro is nested inside myinc.inc. Once you
exit myinc.inc, the local A is destroyed and the original A with its value of 123
is now in effect. Once you have created the local A inside myinc.inc, there is no way to
reference the original global A unless you #undef A or exit the include file. Using #undef
always undefines the most local version of an identifier.
Similarly if MyMacro contained...
#local B = box{0,1}
then a new identifier B is created local to the macro only. The original value of B
remains hidden but is restored when the macro is finished. The local B need not have the same type as the
original.
The complication comes when trying to assign a new value to an identifier at one level that was declared local at
an earlier level. Suppose inside myinc.inc you do...
#local D = 789;
If you are inside myinc.inc and you want to increment D by one, you might try to do...
#local D = D + 1;
but if you try to do that inside MyMacro you will create a new D which is local to MyMacro
and not the D which is external to MyMacro but local to myinc.inc. Therefore
you've said "create a MyMacro D from the value of myinc.inc's D plus
one". That's probably not what you wanted. Instead you should do...
#declare D = D + 1;
You might think this creates a new D that is global but it actually increments the myinc.inc version
of D. Confusing isn't it? Here are the rules:
When referencing an identifier, you always get the most recent, most local version. By "referencing" we
mean using the value of the identifier in a POV-Ray statement or using it on the right of an equals sign in either a
#declare
or #local.
When declaring an identifier using the
#local keyword, the identifier which is created or has a new
value assigned, is ALWAYS created at the current nesting level of macros or include files.
When declaring a NEW, NON-EXISTANT identifier using
#declare, it is created as fully global. It is
put in the symbol table of the main scene file.
When ASSIGNING A VALUE TO AN EXISTING identifier using
#declare, it assigns it to the most recent,
most local version at the time.
In summary, #local always means "the current level", and #declare means
"global" for new identifiers and "most recent" for existing identifiers.
2.2.2.2.4 Destroying Identifiers with #undef
Identifiers created with #declare will generally persist until parsing is complete. Identifiers
created with #local will persist until the end of the macro or include file in which they were created.
You may however un-define an identifier using the #undef directive. For example:
#undef MyValue
If multiple local nested versions of the identifier exist, the most local most recent version is deleted and any
identically named identifiers which were created at higher levels will still exist.
See also "The #ifdef and #ifndef Directives".
More about "#macro"
