3.4.3 The Status Bar
At the bottom of the main window is a status bar. The left part of the status bar contains an information and help
field. After that comes the current line and column of the editor caret, followed by a panel that shows 'INS' for
editor insert mode, and 'OVR' for overwrite mode. Next to this you will find a Pixel-Per-Second indicator and a clock
showing time elapsed (in days-hours-minutes-seconds) since the beginning of the last render job. This clock stops when
the job completes. Note that on extremely slow renders, the PPS indicator may change to showing PPM (pixels per
minute), or PPH (pixels per hour). Note also that the clock shows only elapsed time - not CPU time. As Windows is a
multi-tasking operating system the two are not the same (though if you are running no other applications they will be
fairly close).
