Describe a color or pattern of colors for a texture:
PIGMENT:
Jump to SDL
pigment { PIGMENT_BODY }
PIGMENT_BODY:
[PIGMENT_IDENTIFIER] [PIGMENT_TYPE] [PIGMENT_MODIFIERS]
PIGMENT_TYPE:
COLOR | COLOR_LIST_PATTERN | PIGMENT_LIST_PATTERN | IMAGE_MAP | MAP_PATTERN [COLOR_MAP] |
MAP_PATTERN PIGMENT_MAP
COLOR_LIST_PATTERN:
brick [COLOR [, COLOR]] [BRICK_ITEMS] | checker
[COLOR [, COLOR]] | hexagon [COLOR [, COLOR [, COLOR]]] | object { LIST_OBJECT
[COLOR [, COLOR]] }
PIGMENT_LIST_PATTERN:
brick PIGMENT, PIGMENT [BRICK_ITEMS] | checker
PIGMENT, PIGMENT | hexagon PIGMENT, PIGMENT, PIGMENT | object { LIST_OBJECT
PIGMENT, PIGMENT }
IMAGE_MAP:
image_map {BITMAP_IMAGE
[IMAGE_MAP_MODIFIER...] [BITMAP_MODIFIERS] }
IMAGE_MAP_MODIFIER:
filter I_PALETTE, F_AMOUNT | filter all F_AMOUNT | transmit I_PALETTE, F_AMOUNT
| transmit all F_AMOUNT
COLOR_MAP:
color_map { COLOR_MAP_BODY } [BLEND_MAP_MODIFIERS]
| colour_map { COLOR_MAP_BODY } [BLEND_MAP_MODIFIERS]
COLOR_MAP_BODY:
COLOR_MAP_IDENTIFIER | COLOR_MAP_ENTRY...
There may be from 2 to 256 map entries.
COLOR_MAP_ENTRY:
[ FLOAT COLOR ]
The brackets here are part of the map entry.
PIGMENT_MAP:
pigment_map { PIGMENT_MAP_BODY } [BLEND_MAP_MODIFIERS]
PIGMENT_MAP_BODY:
PIGMENT_MAP_IDENTIFIER | PIGMENT_MAP_ENTRY...
PIGMENT_MAP_ENTRY:
[ FLOAT PIGMENT_BODY ]
PIGMENT_MODIFIERS:
[QUICK_COLOR] & [PATTERN_MODIFIERS]
QUICK_COLOR:
quick_color COLOR | quick_colour COLOR
Quick Reference Contents
More about "Jump to SDL"
