See the Selection Sub-Menu.
No indentation occurs. The next line begins at column 1.
Language-specific scoping is used to determine the correct indentation level for the next line. This setting causes
the editor to parse the buffer contents, looking backward for scope keywords until the start of the current scope is
encountered. Once found, the indentation is copied to the next line. If no language is set, the editor acts as if
'Copy From Previous Line' was chosen.
3.5.4.4.4 Copy From Previous Line
Indentation is copied from the previous line.
