2.1.2.1 Animation Options
Internal animation loop, automatic output file name numbering and the ability to shell out to the operating system
to external utilities which can assemble individual frames into an animation, greatly improved the animation
capability. The internal animation loop is simple yet flexible. You may still use external programs or batch files to
create animations without the internal loop.
2.1.2.1.1 External Animation Loop
Clock=n.n
Sets clock float identifier to n.n
+Kn.n
Same as Clock=n.n
The Clock=n.n option or the +Kn.n switch may be used to pass a single
float value to the program for basic animation. The value is stored in the float identifier clock. If an
object had a rotate <0,clock,0> attached then you could rotate the object by different amounts over
different frames by setting +K10.0,+K20.0... etc. on successive renderings. It is up to the
user to repeatedly invoke POV-Ray with a different Clock value and a different Output_File_Name
for each frame.
2.1.2.1.2 Internal Animation Loop
Initial_Frame=n
Sets initial frame number to n
Final_Frame=n
Sets final frame number to n
Initial_Clock=n.n
Sets initial clock value to n.n
Final_Clock=n.n
Sets final clock value to n.n
+KFIn
Same as Initial_Frame=n
+KFFn
Same as Final_Frame=n
+KIn.n
Same as Initial_Clock=n.n
+KFn.n
Same as Final_Clock=n.n
The internal animation loop relieves the user of the task of generating complicated sets of batch files to invoke
POV-Ray multiple times with different settings. While the multitude of options may look intimidating, the clever set
of default values means that you will probably only need to specify the Final_Frame=n or the +KFFn
option to specify the number of frames. All other values may remain at their defaults.
Any Final_Frame setting other than -1 will trigger POV-Ray's internal animation loop. For example
Final_Frame=10 or +KFF10 causes POV-Ray to render your scene 10 times. If you specified Output_File_Name=file.tga
then each frame would be output as file01.tga, file02.tga, file03.tga etc. The
number of zero-padded digits in the file name depends upon the final frame number. For example +KFF100
would generate file001.tga through file100.tga. The frame number may encroach upon the file
name. On MS-DOS with an eight character limit, myscene.pov would render to mysce001.tga
through mysce100.tga.
The default Initial_Frame=1 will probably never have to be changed. You would only change it if you
were assembling a long animation sequence in pieces. One scene might run from frame 1 to 50 and the next from 51 to
100. The Initial_Frame=n or +KFIn option is for this purpose.
Note: if you wish to render a subset of frames such as 30 through 40 out of a 1 to
100 animation, you should not change Initial_Frame or Final_Frame. Instead you should use
the subset commands described in section "Subsets of Animation Frames".
Unlike some animation packages, the action in POV-Ray animated scenes does not depend upon the integer frame
numbers. Rather you should design your scenes based upon the float identifier clock.
By default, the clock value is 0.0 for the initial frame and 1.0 for the final frame. All other frames are
interpolated between these values. For example if your object is supposed to rotate one full turn over the course of
the animation, you could specify rotate 360*clock*y. Then as clock runs from 0.0 to 1.0, the object
rotates about the y-axis from 0 to 360 degrees.
The major advantage of this system is that you can render a 10 frame animation or a 100 frame or 500 frame or 329
frame animation yet you still get one full 360 degree rotation. Test renders of a few frames work exactly like final
renders of many frames.
In effect you define the motion over a continuous float valued parameter (the clock) and you take discrete samples
at some fixed intervals (the frames). If you take a movie or video tape of a real scene it works the same way. An
object's actual motion depends only on time. It does not depend on the frame rate of your camera.
Many users have already created scenes for POV-Ray 2 that expect clock values over a range other than the default
0.0 to 1.0. For this reason we provide the Initial_Clock=n.n or +KIn.n and Final_Clock=n.n
or +KFn.n options. For example to run the clock from 25.0 to 75.0 you would specify Initial_Clock=25.0
and Final_Clock=75.0. Then the clock would be set to 25.0 for the initial frame and 75.0 for the final
frame. In-between frames would have clock values interpolated from 25.0 through 75.0 proportionally.
Users who are accustomed to using frame numbers rather than clock values could specify Initial_Clock=1.0
and Final_Clock=10.0 and Frame_Final=10 for a 10 frame animation.
For new scenes, we recommend you do not change the Initial_Clock or Final_Clock from
their default 0.0 to 1.0 values. If you want the clock to vary over a different range than the default 0.0 to 1.0, we
recommend you handle this inside your scene file as follows...
#declare Start = 25.0;
#declare End = 75.0;
#declare My_Clock = Start+(End-Start)*clock;
Then use My_Clock in the scene description. This keeps the critical values 25.0 and 75.0 in your .pov
file.
Note: more details concerning the inner workings of the animation loop are in the
section on shell-out operating system commands in section "Shell-out to
Operating System".
2.1.2.1.3 Subsets of Animation Frames
Subset_Start_Frame=n
Set subset starting frame to n
Subset_Start_Frame=0.n
Set subset starting frame to n percent
Subset_End_Frame=n
Set subset ending frame to n
Subset_End_Frame=0.n
Set subset ending frame to n percent
+SF0.n
Same as Subset_Start_Frame
+EF0.n
Same as Subset_End_Frame
When creating a long animation, it may be handy to render only a portion of the animation to see what it looks
like. Suppose you have 100 frames but only want to render frames 30 through 40. If you set Initial_Frame=30
and Final_Frame=40 then the clock would vary from 0.0 to 1.0 from frames 30 through 40 rather than 0.30
through 0.40 as it should. Therefore you should leave Initial_Frame=1 and Final_Frame=100
and use Subset_Start_Frame=30 and Subset_End_Frame=40 to selectively render part of the
scene. POV-Ray will then properly compute the clock values.
Usually you will specify the subset using the actual integer frame numbers however an alternate form of the subset
commands takes a float value in the range 0.0 <=n.nnn <=1.0 which is interpreted as a fraction of the
whole animation. For example, Subset_Start_Frame=0.333 and Subset_End_Frame=0.667 would
render the middle 1/3rd of a sequence regardless of the number of frames.
Cyclic_Animation=bool
Turn cyclic animation on/off
+KC
-KC
Turn cyclic animation off
Many computer animation sequences are designed to be run in a continuous loop. Suppose you have an object that
rotates exactly 360 degrees over the course of your animation and you did rotate 360*clock*y to do so.
Both the first and last frames would be identical. Upon playback there would be a brief one frame jerkiness. To
eliminate this problem you need to adjust the clock so that the last frame does not match the first. For example a ten
frame cyclic animation should not use clock 0.0 to 1.0. It should run from 0.0 to 0.9 in 0.1 increments. However if
you change to 20 frames it should run from 0.0 to 0.95 in 0.05 increments. This complicates things because you would
have to change the final clock value every time you changed Final_Frame. Setting Cyclic_Animation=on
or using +KC will cause POV-Ray to automatically adjust the final clock value for cyclic animation
regardless of how many total frames. The default value for this setting is off.
Field_Render=bool
Turn field rendering on/off
Odd_Field=bool
Set odd field flag
+UF
-UF
Turn field rendering off
+UO
Set odd field flag on
-UO
Set odd field flag off
Field rendering is sometimes used for animations when the animation is being output for television. TVs only
display alternate scan lines on each vertical refresh. When each frame is being displayed the fields are interlaced to
give the impression of a higher resolution image. The even scan lines make up the even field, and are drawn first
(i.e. scan lines 0, 2, 4, etc.), followed by the odd field, made up of the odd numbered scan lines are drawn
afterwards. If objects in an animation are moving quickly, their position can change noticeably from one field to the
next. As a result, it may be desirable in these cases to have POV-Ray render alternate fields at the actual field rate
(which is twice the frame rate), rather than rendering full frames at the normal frame rate. This would save a great
deal of time compared to rendering the entire animation at twice the frame rate, and then only using half of each
frame.
By default, field rendering is not used. Setting Field_Render=on or using +UF will
cause alternate frames in an animation to be only the even or odd fields of an animation. By default, the first frame
is the even field, followed by the odd field. You can have POV-Ray render the odd field first by specifying
Odd_Field=on, or by using the +UO switch.
