The MRU (most recently used) file list holds up to nine (9) files. The Older Files menu (see above) holds up to 32
additional files. After a file scrolls off the bottom of the MRU list it goes into the top of the Older Files menu.
When you select a file from the MRU list, if it is already open in the editor, it is selected and moved to the top
of the MRU list. Otherwise, it is opened and moved to the top of the list. The MRU list remembers several things about
files, including the last line, column, and top line number, plus the tab, language, and indent settings. The comments
in this paragraph also apply to the Older Files menu.
