The hf_gray_16 setting is useful when using POV-Ray to generate heightfields for use in other POV-Ray
scenes. The syntax is... global_settings { hf_gray_16 [Bool] }
The boolean value turns the option on or off. If the keyword is specified without the boolean value then the option
is turned on. If hf_gray_16 is not specified in any global_settings statement in the entire
scene then the default is off.
When hf_gray_16 is on, the output file will be in the form of a heightfield, with the height at any
point being dependent on the brightness of the pixel. The brightness of a pixel is calculated in the same way that
color images are converted to grayscale images: height = 0.3 * red + 0.59 * green + 0.11 * blue.
Setting the hf_gray_16 option will cause the preview display, if used, to be grayscale rather than
color. This is to allow you to see how the heightfield will look because some file formats store heightfields in a way
that is difficult to understand afterwards. See section "Height Field"
for a description of how POV-Ray heightfields are stored for each file type.
