2.1.2.4 File Output Options
Output_to_File=bool
Sets file output on/off
+F
Sets file output on (use default type)
-F
Sets file output off
By default, POV-Ray writes an image file to disk. When you are developing a scene and doing test renders, the
graphic preview may be sufficient. To save time and disk activity you may turn file output off with
Output_to_File=off or -F.
Output_File_Type=x
Sets file output format to x
+Fxn
Sets file output on; sets format x, depth n
-Fxn
Sets file output off; but in future use format x, depth n
Output_Alpha=bool
Sets alpha output on/off
+UA
-UA
Sets alpha output off
Bits_Per_Color=n
Sets file output bits/color to n
The default type of image file depends on which platform you are using. MS-DOS and most others default to 24-bit
uncompressed Targa. Windows defaults to 'sys', which is 24-bit BMP. See your platform-specific documentation to see
what your default file type is. You may select one of several different file types using Output_File_Type=x
or +Fx where x is one of the following...
.. C
Compressed Targa-24 format (RLE, run length encoded)
.. N
PNG (portable network graphics) format
.. P
Unix PPM format
.. S
System-specific such as Mac Pict or Windows BMP
.. T
Uncompressed Targa-24 format
Note: the obsolete +FD dump format and +FR raw format have
been dropped because they were rarely used and no longer necessary. PPM, PNG, and system specific formats have been
added. PPM format images are uncompressed, and have a simple text header, which makes it a widely portable image
format. PNG is an image format designed not only to replace GIF, but to improve on its shortcomings. PNG offers the
highest compression available without loss for high quality applications, such as ray-tracing. The system specific
format depends on the platform used and is covered in the appropriate system specific documentation.
Most of these formats output 24 bits per pixel with 8 bits for each of red, green and blue data. PNG and PPM allow
you to optionally specify the output bit depth from 5 to 16 bits for each of the red, green, and blue colors, giving
from 15 to 48 bits of color information per pixel. The default output depth for all formats is 8 bits/color (16
million possible colors), but this may be changed for PNG and PPM format files by setting Bits_Per_Color=n
or by specifying +FNn or +FPn, where n is the desired bit depth.
Specifying a smaller color depth like 5 bits/color (32768 colors) may be enough for people with 8- or 16-bit (256
or 65536 color) displays, and will improve compression of the PNG file. Higher bit depths like 10 or 12 may be useful
for video or publishing applications, and 16 bits/color is good for grayscale height field output (See section "Height
Field" for details on height fields).
Targa format also allows 8 bits of alpha transparency data to be output, while PNG format allows 5 to 16 bits of
alpha transparency data, depending on the color bit depth as specified above. You may turn this option on with
Output_Alpha=on or +UA. The default is off or -UA.
The alpha channel stores a transparency value for each pixel, just like there is also stored a value for red green
and blue light for each pixel. In POV-Ray, when the alpha channel is turned on, all areas of the image where the
background is partly or fully visible will be partly or fully transparent. Refractions of the background will also be
transparent, but not reflections. Also anti-aliasing is taken into account
The philosophy of the alpha channel feature in POV-Ray is that the background color should not be present in the
color of the image when the alpha channel is used. Instead, the amount of visible background is kept in the alpha and
*only* in the alpha channel. That ensures that images look correct when viewed with the alpha channel.
See section "Using the Alpha Channel" for further details on
using transparency in imagemaps in your scene.
In addition to support for variable bit-depths, alpha channel, and grayscale formats, PNG files also store the
Display_Gamma value so the image displays properly on all systems (see section "Display
Hardware Settings"). The hf_gray_16 global setting, as described in section "HF_Gray_16"
will also affect the type of data written to the output file.
Output_File_Name=file
Sets output file to file
+Ofile
Same as Output_File_Name=file
The default output filename is created from the scene name and need not be specified. The scene name is the input
name with all drive, path, and extension information stripped. For example if the input file name is
c:\povray3\mystuff\myfile.pov the scene name is myfile. The proper extension is appended to the
scene name based on the file type. For example myfile.tga or myfile.png might be used.
You may override the default output name using Output_File_Name=file or +Ofile.
For example:
Input_File_Name=myinput.pov
Output_File_Name=myoutput.tga
If an output file name of "-" is specified (a single minus sign), then the image will be written to
standard output, usually the screen. The output can then be piped into another program or to a GUI if desired.
If the file specified is actually a path or directory or folder name and not a file name, then the default output name
is used but it is written to the specified directory. For example:
Input_File_Name=myscene.pov
Output_File_Name=c:\povray3\myimages\
This will create c:\povray3\myimages\myscene.tga as the output file.
2.1.2.4.3 Output File Buffer
The output-file buffer options Buffer_Output and Buffer_Size are removed per POV-Ray 3.6
Note: the options are still accepted, but ignored, in order to be backward compatible
with old INI files.
2.1.2.4.4 CPU Utilization Histogram
The CPU utilization histogram is a way of finding out where POV-Ray is spending its rendering time, as well as an
interesting way of generating heightfields. The histogram splits up the screen into a rectangular grid of blocks. As
POV-Ray renders the image, it calculates the amount of time it spends rendering each pixel and then adds this time to
the total rendering time for each grid block. When the rendering is complete, the histogram is a file which represents
how much time was spent computing the pixels in each grid block.
Not all versions of POV-Ray allow the creation of histograms. The histogram output is dependent on the file type
and the system that POV-Ray is being run on.
Histogram_Type=y
Set histogram type to y (Turn off if type is 'X')
+HTy
Same as Histogram_Type=y
The histogram output file type is nearly the same as that used for the image output file types in "Output File
Type". The available histogram file types are as follows.
+HTC
Comma separated values (CSV) often used in spreadsheets
+HTN
PNG (portable network graphics) format grayscale
+HTP
Unix PPM format
+HTS
+HTT
Uncompressed Targa-24 format (TGA)
+HTX
No histogram file output is generated
Note: +HTC does not generate a compressed Targa-24 format output file
but rather a text file with a comma-separated list of the time spent in each grid block, in left-to-right and top-to
bottom order. The units of time output to the CSV file are system dependent. See the system specific documentation for
further details on the time units in CSV files.
The Targa and PPM format files are in the POV heightfield format (see "Height
Field"), so the histogram information is stored in both the red and green parts of the image, which makes it
unsuitable for viewing. When used as a height field, lower values indicate less time spent calculating the pixels in
that block, while higher indicate more time spent in that block.
PNG format images are stored as grayscale images and are useful for both viewing the histogram data as well as for
use as a heightfield. In PNG files, the darker (lower) areas indicate less time spent in that grid block, while the
brighter (higher) areas indicate more time spent in that grid block.
Histogram_Name=file
Set histogram name to file
+HNfile
Same as Histogram_Name=file
The histogram file name is the name of the file in which to write the histogram data. If the file name is not
specified it will default to histogram.ext, where ext is based on the file type specified
previously.
Note: that if the histogram name is specified the file name extension should match
the file type.
Histogram_Grid_Size= nn.mm
Set histogram grid to nn by mm
+HSnn.mm
Same as Histogram_Grid_Size=nn.mm
The histogram grid size gives the number of times the image is split up in both the horizontal and vertical
directions. For example
will split the image into 160*120 grid blocks, each of size 4*4 pixels, and output a PNG file, suitable for viewing
or for use as a heightfield. Smaller numbers for the grid size mean more pixels are put into the same grid block. With
CSV output, the number of values output is the same as the number of grid blocks specified. For the other formats the
image size is identical to the rendered image rather than the specified grid size, to allow easy comparison between
the histogram and the rendered image. If the histogram grid size is not specified, it will default to the same size as
the image, so there will be one grid block per pixel.
Note: on systems that do task-switching or multi-tasking the histogram may not
exactly represent the amount of time POV-Ray spent in a given grid block since the histogram is based on real time
rather than CPU time. As a result, time may be spent for operating system overhead or on other tasks running at the
same time. This will cause the histogram to have speckling, noise or large spikes. This can be reduced by decreasing
the grid size so that more pixels are averaged into a given grid block.
