The radial pattern is a radial blend that wraps around the +y-axis. The color for value 0.0 starts at
the +x-direction and wraps the color map around from east to west with 0.25 in the -z-direction, 0.5 in -x, 0.75 at +z
and back to 1.0 at +x. Typically the pattern is used with a frequency modifier to create multiple bands
that radiate from the y-axis. For example:
radial color_map{[0.5 Black][0.5 White]}
frequency 10
creates 10 white bands and 10 black bands radiating from the y axis.
The radial pattern has a default color_map built in that results in a yellow, magenta and cyan pattern
with smooth transitions.
