Normally the light source itself has no visible shape. The light simply radiates from an invisible point or area.
You may give a light source any shape by adding a looks_like { OBJECT } statement.
There is an implied no_shadow attached to the looks_like object so that light is not
blocked by the object. Without the automatic no_shadow the light inside the object would not escape. The
object would, in effect, cast a shadow over everything.
If you want the attached object to block light then you should attach it with a union and not a looks_like
as follows:
union {
light_source { <100, 200, -300> color White }
object { My_Lamp_Shape }
Presumably parts of the lamp shade are transparent to let some light out.
