2.4.3.2 Poly, Cubic and Quartic
Higher order polynomial surfaces may be defined by the use of a poly shape. The syntax is
POLY:
poly
Order, <A1, A2, A3,... An>
[POLY_MODIFIERS...]
POLY_MODIFIERS:
sturm | OBJECT_MODIFIER
Poly default values:
sturm : off
where Order is an integer number from 2 to 15 inclusively that specifies the order of the
equation. A1, A2, ... An are float values for the coefficients of the equation. There are n
such terms where n = ((Order+1)*(Order+2)*(Order+3))/6.
The cubic object is an alternate way to specify 3rd order polys. Its syntax is:
CUBIC:
cubic
<A1, A2, A3,... A20>
[POLY_MODIFIERS...]
Also 4th order equations may be specified with the quartic object. Its syntax is:
QUARTIC:
quartic
<A1, A2, A3,... A35>
[POLY_MODIFIERS...]
The following table shows which polynomial terms correspond to which x,y,z factors for the orders 2 to 7. Remember cubic
is actually a 3rd order polynomial and quartic is 4th order.
Cubic and quartic polynomial terms
| | 2nd | 3rd | 4th | 5th | 6th | 7th |
| 5th | 6th | 7th |
| 6th | 7th |
A1
x2
x3
x4
x5
x6
x7
A41
y3
xy3
x2y3
A81
z3
xz3
A2
xy
x2y
x3y
x4y
x5y
x6y
A42
y2z3
xy2z3
x2y2z3
A82
z2
xz2
A3
xz
x2z
x3z
x4z
x5z
x6z
A43
y2z2
xy2z2
x2y2z2
A83
z
xz
A4
x
x2
x3
x4
x5
x6
A44
y2z
xy2z
x2y2z
A84
1
x
A5
y2
xy2
x2y2
x3y2
x4y2
x5y2
A45
y2
xy2
x2y2
A85
y7
A6
yz
xyz
x2yz
x3yz
x4yz
x5yz
A46
yz4
xyz4
x2yz4
A86
y6z
A7
y
xy
x2y
x3y
x4y
x5y
A47
yz3
xyz3
x2yz3
A87
y6
A8
z2
xz2
x2z2
x3z2
x4z2
x5z2
A48
yz2
xyz2
x2yz2
A88
y5z2
A9
z
xz
x2z
x3z
x4z
x5z
A49
yz
xyz
x2yz
A89
y5z
A10
1
x
x2
x3
x4
x5
A50
y
xy
x2y
A90
y5
A11
y3
xy3
x2y3
x3y3
x4y3
A51
z5
xz5
x2z5
A91
y4z3
A12
y2z
xy2z
x2y2z
x3y2z
x4y2z
A52
z4
xz4
x2z4
A92
y4z2
A13
y2
xy2
x2y2
x3y2
x4y2
A53
z3
xz3
x2z3
A93
y4z
A14
yz2
xyz2
x2yz2
x3yz2
x4yz2
A54
z2
xz2
x2z2
A94
y4
A15
yz
xyz
x2yz
x3yz
x4yz
A55
z
xz
x2z
A95
y3z4
A16
y
xy
x2y
x3y
x4y
A56
1
x
x2
A96
y3z3
A17
z3
xz3
x2z3
x3z3
x4z3
A57
y6
xy6
A97
y3z2
A18
z2
xz2
x2z2
x3z2
x4z2
A58
y5z
xy5z
A98
y3z
A19
z
xz
x2z
x3z
x4z
A59
y5
xy5
A99
y3
A20
1
x
x2
x3
x4
A60
y4z2
xy4z2
A100
y2z5
A21
y4
xy4
x2y4
x3y4
A61
y4z
xy4z
A101
y2z4
A22
y3z
xy3z
x2y3z
x3y3z
A62
y4
xy4
A102
y2z3
A23
y3
xy3
x2y3
x3y3
A63
y3z3
xy3z3
A103
y2z2
A24
y2z2
xy2z2
x2y2z2
x3y2z2
A64
y3z2
xy3z2
A104
y2z
A25
y2z
xy2z
x2y2z
x3y2z
A65
y3z
xy3z
A105
y2
A26
y2
xy2
x2y2
x3y2
A66
y3
xy3
A106
yz6
A27
yz3
xyz3
x2yz3
x3yz3
A67
y2z4
xy2z4
A107
yz5
A28
yz2
xyz2
x2yz2
x3yz2
A68
y2z3
xy2z3
A108
yz4
A29
yz
xyz
x2yz
x3yz
A69
y2z2
xy2z2
A109
yz3
A30
y
xy
x2y
x3y
A70
y2z
xy2z
A110
yz2
A31
z4
xz4
x2z4
x3z4
A71
y2
xy2
A111
yz
A32
z3
xz3
x2z3
x3z3
A72
yz5
xyz5
A112
y
A33
z2
xz2
x2z2
x3z2
A73
yz4
xyz4
A113
z7
A34
z
xz
x2z
x3z
A74
yz3
xyz3
A114
z6
A35
1
x
x2
x3
A75
yz2
xyz2
A115
z5
A36
y5
xy5
x2y5
A76
yz
xyz
A116
z4
A37
y4z
xy4z
x2y4z
A77
y
xy
A117
z3
A38
y4
xy4
x2y4
A78
z6
xz6
A118
z2
A39
y3z2
xy3z2
x2y3z2
A79
z5
xz5
A119
z
A40
y3z
xy3z
x2y3z
A80
z4
xz4
A120
1
Polynomial shapes can be used to describe a large class of shapes including the torus, the lemniscate, etc. For
example, to declare a quartic surface requires that each of the coefficients (A1 ... A35) be
placed in order into a single long vector of 35 terms. As an example let's define a torus the hard way. A Torus can be
represented by the equation: x4 + y4 + z4 + 2 x2 y2 + 2 x2
z2 + 2 y2 z2 - 2 (r_02 + r_12) x2 + 2 (r_02 - r_12) y2 - 2
(r_02 + r_12) z2 + (r_02 - r_12)2 = 0
Where r_0 is the major radius of the torus, the distance from the hole of the donut to the middle of the ring of
the donut, and r_1 is the minor radius of the torus, the distance from the middle of the ring of the donut to the
outer surface. The following object declaration is for a torus having major radius 6.3 minor radius 3.5 (Making the
maximum width just under 20).
// Torus having major radius sqrt(40), minor radius sqrt(12)
quartic {
< 1, 0, 0, 0, 2, 0, 0, 2, 0,
-104, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 1, 0, 0, 2, 0, 56, 0,
0, 0, 0, 1, 0, -104, 0, 784 >
sturm
Poly, cubic and quartics are just like quadrics in that you do not have to understand one to use one. The file
shapesq.inc has plenty of pre-defined quartics for you to play with.
Polys use highly complex computations and will not always render perfectly. If the surface is not smooth, has
dropouts, or extra random pixels, try using the optional keyword sturm in the definition. This will cause
a slower but more accurate calculation method to be used. Usually, but not always, this will solve the problem. If
sturm does not work, try rotating or translating the shape by some small amount.
There are really so many different polynomial shapes, we cannot even begin to list or describe them all. We suggest
you find a good reference or text book if you want to investigate the subject further.
