When light passes through a surface either into or out of a dense medium the path of the ray of light is bent. Such
bending is called refraction. The amount of bending or refracting of light depends upon the density of the
material. Air, water, crystal and diamonds all have different densities and thus refract differently. The index of
refraction or ior value is used by scientists to describe the relative density of substances. The ior
keyword is used in POV-Ray in the interior to turn on refraction and to specify the ior value. For
example:
object { MyObject pigment {Clear } interior { ior 1.5 } }
The default ior value of 1.0 will give no refraction. The index of refraction for air is 1.0, water is 1.33, glass
is 1.5 and diamond is 2.4.
Normally transparent or semi-transparent surfaces in POV-Ray do not refract light. Earlier versions of POV-Ray
required you to use the refraction keyword in the finish statement to turn on refraction.
This is no longer necessary. Any non-zero ior value now turns refraction on.
In addition to turning refraction on or off, the old refraction keyword was followed by a float value
from 0.0 to 1.0. Values in between 0.0 and 1.0 would darken the refracted light in ways that do not correspond to any
physical property. Many POV-Ray scenes were created with intermediate refraction values before this bug was discovered
so the feature has been maintained. A more appropriate way to reduce the brightness of refracted light is to change
the filter or transmit
value in the colors specified in the pigment statement or to use the fade_power
and fade_distance keywords. See "Attenuation".
Note: neither the ior nor refraction keywords cause the
object to be transparent. Transparency only occurs if there is a non-zero filter or transmit
value in the color.
The refraction and ior keywords were originally specified in finish but are
now properly specified in interior. They are accepted in finish for
backward compatibility and generate a warning message.
More about "finish"
