Ray-tracing is known for the dramatic way it depicts reflection, refraction and lighting effects. Much of our
perception depends on the reflective properties of an object. Ray tracing can exploit this by playing tricks on our
perception to make us see complex details that are not really there.
Suppose you wanted a very bumpy surface on the object. It would be very difficult to mathematically model lots of
bumps. We can however simulate the way bumps look by altering the way light reflects off of the surface. Reflection
calculations depend on a vector called a surface normal vector. This is a vector which points away from the
surface and is perpendicular to it. By artificially modifying (or perturbing) this normal vector you can simulate
bumps. This is done by adding an optional normal statement.
Note: that attaching a normal pattern does not really modify the surface. It only
affects the way light reflects or refracts at the surface so that it looks bumpy.
The syntax is:
NORMAL:
normal { [NORMAL_IDENTIFIER] [NORMAL_TYPE] [NORMAL_MODIFIER...] }
NORMAL_TYPE:
PATTERN_TYPE Amount |
bump_map { BITMAP_TYPE "bitmap.ext" [BUMP_MAP_MODS...]}
NORMAL_MODIFIER:
PATTERN_MODIFIER | NORMAL_LIST | normal_map { NORMAL_MAP_BODY } |
slope_map{ SLOPE_MAP_BODY } | bump_size Amount |
no_bump_scale Bool | accuracy Float
Each of the items in a normal are optional but if they are present, they must be in the order shown. Any items
after the NORMAL_IDENTIFIER modify or override settings given in the identifier. If no identifier is
specified then the items modify the normal values in the current default texture. The PATTERN_TYPE may
optionally be followed by a float value that controls the apparent depth of the bumps. Typical values range from 0.0
to 1.0 but any value may be used. Negative values invert the pattern. The default value if none is specified is 0.5.
There are four basic types of NORMAL_TYPEs. They are block pattern normals, continuous pattern normals,
specialized normals and bump maps. They differ in the types of modifiers you may use with them. The pattern type is
optionally followed by one or more normal modifiers. In addition to general pattern modifiers such as transformations,
turbulence, and warp modifiers, normals may also have a NORMAL_LIST, slope_map, normal_map,
and bump_size which are specific to normals. See "Pattern Modifiers" for
information on general modifiers. The normal-specific modifiers are described in sub-sections which follow. Normal
modifiers of any kind apply only to the normal and not to other parts of the texture. Modifiers must be specified
last.
Originally POV-Ray had some patterns which were exclusively used for pigments while others were exclusively used
for normals. Since POV-Ray 3.0 you can use any pattern for either pigments or normals. For example it is now valid to
use ripples as a pigment or wood as a normal type. The patterns bumps, dents,
ripples, waves, wrinkles, and bump_map were once exclusively
normal patterns which could not be used as pigments. Because these six types use specialized normal modification
calculations they cannot have slope_map, normal_map or wave shape modifiers. All other
normal pattern types may use them. Because block patterns checker, hexagon, object
and brick do not return a continuous series of values, they cannot use these modifiers either. See "Patterns"
for details about specific patterns.
A normal statement is part of a texture specification. However it can be tedious to use
a texture statement just to add bumps to an object. Therefore you may attach a normal directly to an
object without explicitly specifying that it as part of a texture. For example instead of this:
object {My_Object texture { normal { bumps 0.5 } } }
you may shorten it to:
object { My_Object normal { bumps 0.5 } }
Doing so creates an entire texture structure with default pigment and finish
statements just as if you had explicitly typed the full texture {...} around it. Normal identifiers may
be declared to make scene files more readable and to parameterize scenes so that changing a single declaration changes
many values. An identifier is declared as follows.
NORMAL_DECLARATION:
#declare IDENTIFIER = NORMAL |
#local IDENTIFIER = NORMAL
Where IDENTIFIER is the name of the identifier up to 40 characters long and NORMAL is any valid normal
statement. See "#declare vs. #local" for information on
identifier scope.
More about "Pattern Modifiers"
