The color or pattern of colors for an object is defined by a pigment statement. All plain textures
must have a pigment. If you do not specify one the default pigment is used. The color you define is the way you want
the object to look if fully illuminated. You pick the basic color inherent in the object and POV-Ray brightens or
darkens it depending on the lighting in the scene. The parameter is called pigment because we are
defining the basic color the object actually is rather than how it looks.
The syntax for pigment is:
PIGMENT:
[PIGMENT_IDENTIFIER]
[PIGMENT_TYPE]
[PIGMENT_MODIFIER...]
PIGMENT_TYPE:
PATTERN_TYPE | COLOR |
image_map {
BITMAP_TYPE "bitmap.ext" [IMAGE_MAP_MODS...]
PIGMENT_MODIFIER:
PATTERN_MODIFIER | COLOR_LIST | PIGMENT_LIST |
color_map { COLOR_MAP_BODY } | colour_map { COLOR_MAP_BODY } |
pigment_map { PIGMENT_MAP_BODY } | quick_color COLOR |
quick_colour COLOR
Each of the items in a pigment are optional but if they are present, they must be in the order shown. Any items
after the PIGMENT_IDENTIFIER modify or override settings given in the identifier. If no identifier is
specified then the items modify the pigment values in the current default texture. The PIGMENT_TYPE fall into
roughly four categories. Each category is discussed the sub-sections which follow. The four categories are solid color
and image map patterns which are specific to pigment statements or color list patterns, color mapped
patterns which use POV-Ray's wide selection of general patterns. See "Patterns"
for details about specific patterns.
The pattern type is optionally followed by one or more pigment modifiers. In addition to general pattern modifiers
such as transformations, turbulence, and warp modifiers, pigments may also have a COLOR_LIST,
PIGMENT_LIST, color_map, pigment_map, and quick_color which are specific
to pigments. See "Pattern Modifiers" for information on general modifiers. The
pigment-specific modifiers are described in sub-sections which follow. Pigment modifiers of any kind apply only to the
pigment and not to other parts of the texture. Modifiers must be specified last.
A pigment statement is part of a texture specification. However it can be tedious to use a texture
statement just to add a color to an object. Therefore you may attach a pigment directly to an object without
explicitly specifying that it as part of a texture. For example instead of this:
object { My_Object texture {pigment { color Red } } }
you may shorten it to:
object { My_Object pigment {color Red } }
Doing so creates an entire texture structure with default normal and finish
statements just as if you had explicitly typed the full texture {...} around it.
Pigment identifiers may be declared to make scene files more readable and to parameterize scenes so that changing a
single declaration changes many values. An identifier is declared as follows.
PIGMENT_DECLARATION:
#declare IDENTIFIER = PIGMENT |
#local IDENTIFIER = PIGMENT
Where IDENTIFIER is the name of the identifier up to 40 characters long and PIGMENT is any valid pigment
statement. See "#declare vs. #local" for information on
identifier scope.
More about "Pattern Modifiers"
