POV-Ray : Documentation : 1.4.2.3 Rotation behaves very strangely
  POV-Ray 3.6 Documentation Online View
1.4.2.2 I'm getting color banding in the image   1.4.2.4 The image gets distorted when rendering a square image
"When I rotate an object, it dissapears from the image or moves very strangely. Why?"
You need to understand how rotation works in POV-Ray.
Objects are always rotated around the axes. When you rotate, for example, <20,0,0>, that means that you are rotating around the X-axis 20 degrees (counter-clockwise). This is independent of the location of the object: It always rotates around the axis (what is the center of the object anyways? how do you locate it?). This means that if the object is not centered in the axis, it will orbit this axis like the Moon orbits the Earth (showing always the same side to the Earth).
It is a very good practice to define all objects centered at the origin (ie. its 'center' is located at <0,0,0>). Then you can rotate it arbitrarily. After this you can translate it to its proper location in the scene. It is a good idea to do this to every object even if you do not rotate it (because you cannot never say if you will rotate it some day nevertheless).
What if, after all, you have a very complex object defined, but its center is not at the origin, and you want to rotate it around its center? Then you can just translate it to the origin, rotate it and then translate it back to its place. Suppose that the center of the object is located at <10,20,-30>; you can rotate it this way:
translate -<10,20,-30>
rotate <whatever>
translate <10,20,-30>
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
