POV-Ray : Documentation : 5.5.2.1 INI File Sections
  POV-Ray 3.6 Documentation Online View
5.5.2 INI Files   5.6 Understanding POV-Ray Options
Sections are not files in themselves; they are portions of INI files. Sections are a means of grouping multiple sets of POV-Ray options together in a single INI file, by introducing them with a section label. Consider the following INI file, taken from the POV-Ray 3 documentation:
; RES.INI
; This sample INI file is used to set resolution.
+W120 +H100 ; This section has no label.
; Select it with "RES"
[Low]
+W80 +H60 ; This section has a label.
; Select it with "RES[Low]"
[Med]
+W320 +H200 ; This section has a label.
; Select it with "RES[Med]"
[High]
+W640 +H480 ; Labels are not case sensitive.
; "RES[high]" works
[Really High]
+W800 +H600 ; Labels may contain blanks
If you select this INI file, the default resolution setting will be 120 x 100. As soon as you select the [High] section, however, the resolution becomes 640 x 480.
For more information on POV-Ray options and INI files consult the section on POV-Ray Options.
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
