POV-Ray : Documentation : 3.5.10.8 Open <Filename>
  POV-Ray 3.6 Documentation Online View
3.5.10.7 Context Help   3.5.10.9 Copy "..." to Command-Line
Whenever you open the context menu, the editor first looks underneath the edit caret to see if there is a line that looks like a POV-Ray scene file '#include' directive. If one is found, the name of the specified file is placed into the menu in place of "filename". If one is not found, then it may show "Copy ... to Command-Line" (see below).
If you then select this command, the editor will attempt to find and open the file in a new edit window. The standard include paths (as defined in PVENGINE.INI) will be searched if the file is not found relative to the current directory.
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
