POV-Ray : Documentation : 2.7.17.7 Texture and pattern macros
  POV-Ray 3.6 Documentation Online View
2.7.17.6 Special textures   2.7.18 transforms.inc
Irregular_Bricks_Ptrn (Mortar Thickness, X-scaling, Variation, Roundness). This function pattern creates a pattern of bricks of varying lengths on the x-y plane. This can be useful in building walls that do not look like they were built by a computer. Note that mortar thickness between bricks can vary somewhat, too.
Parameters:
  • Mortar Thickness = Thickness of the mortar (0-1).
  • X-scaling = The scaling of the bricks (but not the mortar) in the x direction.
  • Variation = The amount by which brick lengths will vary (0=none, 1=100%).
  • Roundness = The roundness of the bricks (0.01=almost rectangular, 1=very round).
Tiles_Ptrn(). This macro creates a repeating box pattern on the x-y plane. It can be useful for creating grids. The cells shade continuously from the center to the edges.
Parameters: None.
Hex_Tiles_Ptrn(). This macro creates a pattern that is a sort of cross between the hexagon pattern and a repeating box pattern. The hexagonal cells shade continuously from the center to the edges.
Parameters: None.
Star_Ptrn (Radius, Points, Skip). This macro creates a pattern that resembles a star. The pattern is in the x-y plane, centered around the origin.
Parameters:
  • Radius = The radius of a circle drawn through the points of the star.
  • Points = The number of points on the star.
  • Skip = The number of points to skip when drawing lines between points to form the star. A normal 5-pointed star skips 2 points. A Star of David also skips 2 points. Skip must be less than Points/2 and greater than 0. Integers are preferred but not required. Skipping 1 point makes a regular polygon with Points sides.
  • Pigment = The pigment to be applied to the star.
  • Background = The pigment to be applied to the background.
Amazon.com Wish List
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
