2.7.9.1 Float functions and macros
even(N) . A function to test whether N is even, returns 1 when true, 0 when false. Parameters
odd(N) . A function to test whether N is odd, returns 1 when true, 0 when false. Parameters
Interpolate(GC, GS, GE, TS, TE, Method) . Interpolation macro, interpolates between the float values TS
and TE . The method of interpolation is cosine, linear or exponential. The position where to evaluate the
interpolation is determined by the position of GC in the range GS - GE . See
example. Parameters:
GC = global current, float value within the range GS - GE
GS = global start
GE = global end
TS = target start
TE = target end
Method = interpolation method, float value:
Method < 0 : exponential, using the value of Method as exponent.
Method = 0 : cosine interpolation.
Method > 0 : exponential, using the value of Method as exponent.
Method = 1 : linear interpolation,
Example:
#declare A = Interpolate(0.5, 0, 1, 0, 10, 1);
#debug str(A,0,2)
// result A = 5.00
#declare A = Interpolate(0.0,-2, 2, 0, 10, 1);
#debug str(A,0,2)
// result A = 5.00
#declare A = Interpolate(0.5, 0, 1, 0, 10, 2);
#debug str(A,0,2)
// result A = 2.50
Mean(A) . A macro to compute the average of an array of values. Parameters:
A = An array of float or vector values.
Std_Dev(A, M) . A macro to compute the standard deviation. Parameters:
A = An array of float values.
M = Mean of the floats in the array.
GetStats(ValArr) . This macro declares a global array named "StatisticsArray "
containing: N, Mean, Min, Max, and Standard Deviation Parameters:
Histogram(ValArr, Intervals) . This macro declares a global, 2D array named "HistogramArray ".
The first value in the array is the center of the interval/bin, the second the number of values in that interval.
Parameters:
ValArr = An array with values.
Intervals = The desired number of intervals/bins.
sind(v), cosd(v), tand(v), asind(v), acosd(v), atan2d(a, b) . These functions are versions of the
trigonometric functions using degrees, instead of radians, as the angle unit. Parameters: The same as for the
analogous built-in trig function.
max3(a, b, c) . A function to find the largest of three numbers. Parameters:
min3(a, b, c) . A function to find the smallest of three numbers. Parameters:
f_sqr(v) . A function to square a number. Parameters:
sgn(v) . A function to show the sign of the number. Returns -1 or 1 depending on the sign of v.
Parameters:
clip(V, Min, Max) . A function that limits a value to a specific range, if it goes outside that range
it is "clipped". Input values larger than Max will return Max , those less than Min
will return Min . Parameters:
V = Input value.
Min = Minimum of output range.
Max = Maximum of output range.
clamp(V, Min, Max) . A function that limits a value to a specific range, if it goes outside that range
it is "clamped" to this range, wrapping around. As the input increases or decreases outside the given range,
the output will repeatedly sweep through that range, making a "sawtooth" waveform. Parameters:
V = Input value.
adj_range(V, Min, Max) . A function that adjusts input values in the range [0, 1] to a given range. An
input value of 0 will return Min , 1 will return Max , and values outside the [0, 1] range
will be linearly extrapolated (the graph will continue in a straight line). Parameters:
V = Input value.
adj_range2(V, InMin, InMax, OutMin, OutMax) . Like f_range() , but adjusts input values in
the range [InMin, InMax] to the range [OutMin, OutMax] . Parameters:
V = Input value.
InMin = Minimum of input range.
InMax = Maximum of input range.
OutMin = Minimum of output range.
OutMax = Maximum of output range.
