2.7.7.3 Pre defined functions
eval_pigment(Pigm, Vect) , This macro evaluates the color of a pigment at a specific point. Some
pigments require more information than simply a point, slope pattern based pigments for example, and will not work
with this macro. However, most pigments will work fine. Parameters:
Vect = The point at which to evaluate the pigment.
Pigm = The pigment to evaluate.
f_snoise3d(x, y, z) . Just like f_noise3d(), but returns values in the range [-1, 1].
f_sine_wave(val, amplitude, frequency) . Turns a ramping waveform into a sine waveform.
f_scallop_wave(val, amplitude, frequency) . Turns a ramping waveform into a "scallop_wave"
waveform.
Predefined pattern functions, useful for building custom function patterns or performing "displacement
mapping" on isosurfaces. Many of them are not really useful for these purposes, they are simply included for
completeness.
Some are not implemented at all because they require special parameters that must be specified in the definition,
or information that is not available to pattern functions. For this reason, you probably would want to define your own
versions of these functions.
All of these functions take three parameters, the XYZ coordinates of the point to evaluate the pattern at.
f_agate(x, y, z)
f_boxed(x, y, z)
f_bozo(x, y, z)
f_brick(x, y, z)
f_bumps(x, y, z)
f_checker(x, y, z)
f_crackle(x, y, z)
This pattern has many more options, this function uses the defaults.
f_cylindrical(x, y, z)
f_dents(x, y, z)
f_gradientX(x, y, z)
f_gradientY(x, y, z)
f_gradientZ(x, y, z)
f_granite(x, y, z)
f_hexagon(x, y, z)
f_leopard(x, y, z)
f_mandel(x, y, z)
Only the basic mandel pattern is implemented, its variants and the other fractal patterns are not implemented.
f_marble(x, y, z)
f_onion(x, y, z)
f_planar(x, y, z)
f_radial(x, y, z)
f_ripples(x, y, z)
f_spherical(x, y, z)
f_spiral1(x, y, z)
f_spiral2(x, y, z)
f_spotted(x, y, z)
f_waves(x, y, z)
f_wood(x, y, z)
f_wrinkles(x, y, z)
