This file contains a set of macros designed to make debugging easier. It also functions like the old debug.inc,
with the exception that you have to call the Debug_Inc_Stack() macro to get the include stack output.
Debug_Inc_Stack(). Activates include file tracking, each included file will send a debug message when
it is included. Parameters: None.
Set_Debug(Bool). Activate or deactivate the debugging macros. Parameters:
Bool = A boolean (true/false) value.
Debug_Message(Str). If debugging, sends the message to the debug stream. Parameters:
Str = The desired message.
Debug(Condition, Message) Warning(Condition, Message) Error(Condition, Message) These
macros send a message to the #debug, #warning, and #error streams depending on a given condition. They are just a
shortcut for an #if()...#end block, intended to make scenes easier to read. Parameters:
Condition = Any boolean expression.
Message = The message to be sent if Condition evaluates as "true".
