2.5.1.4 Pigment Maps and Pigment Lists
In addition to specifying blended colors with a color map you may create a blend of pigments using a pigment_map.
The syntax for a pigment map is identical to a color map except you specify a pigment in each map entry (and not a
color).
The syntax for pigment_map is as follows:
PIGMENT_MAP:
pigment_map { PIGMENT_MAP_BODY }
PIGMENT_MAP_BODY:
PIGMENT_MAP_IDENTIFIER | PIGMENT_MAP_ENTRY...
PIGMENT_MAP_ENTRY:
[ Value PIGMENT_BODY ]
Where Value is a float value between 0.0 and 1.0 inclusive and each PIGMENT_BODY is
anything which can be inside a pigment{...} statement. The pigment keyword and {}
braces need not be specified.
Note: that the [] brackets are part of the actual PIGMENT_MAP_ENTRY.
They are not notational symbols denoting optional parts. The brackets surround each entry in the pigment map.
There may be from 2 to 256 entries in the map.
For example
sphere {
<0,1,2>, 2
gradient x //this is the PATTERN_TYPE
pigment_map {
[0.3 wood scale 0.2]
[0.3 Jade] //this is a pigment identifier
[0.6 Jade]
[0.9 marble turbulence 1]
When the gradient x function returns values from 0.0 to 0.3 the scaled wood pigment is used. From 0.3
to 0.6 the pigment identifier Jade is used. From 0.6 up to 0.9 a blend of Jade and a turbulent marble is used. From
0.9 on up only the turbulent marble is used.
Pigment maps may be nested to any level of complexity you desire. The pigments in a map may have color maps or
pigment maps or any type of pigment you want. Any entry of a pigment map may be a solid color however if all entries
are solid colors you should use a color_map which will render slightly faster.
Entire pigments may also be used with the block patterns such as checker, hexagon and brick.
For example...
checker
pigment { Jade scale .8 }
pigment { White_Marble scale .5 }
Note: that in the case of block patterns the pigment wrapping is
required around the pigment information.
A pigment map is also used with the average pigment type. See "Average"
for details.
You may not use pigment_map or individual pigments with an image_map. See section "Texture
Maps" for an alternative way to do this.
You may declare and use pigment map identifiers but the only way to declare a pigment block pattern list is to
declare a pigment identifier for the entire pigment.
