POV-Ray : Documentation : 2.4.9.7 No_Image, No_Reflection
  POV-Ray 3.6 Documentation Online View
2.4.9.6 No_Shadow   2.4.9.8 Double_Illuminate
Syntax:
  OBJECT {
    [OBJECT_ITEMS...]
    no_image
    no_reflection
These two keywords are very similar in usage and function to the no_shadow keyword, and control an object's visibility.
You can use any combination of the three with your object.
When no_image is used, the object will not be seen by the camera, either directly or through transparent/refractive objects. However, it will still cast shadows, and show up in reflections (unless no_reflection and/or no_shadow is used also).
When no_reflection is used, the object will not show up in reflections. It will be seen by the camera (and through transparent/refractive objects) and cast shadows, unless no_image and/or no_shadow is used.
Using these three keywords you can produce interesting effects like a sphere casting a rectangular shadow, a cube that shows up as a cone in mirrors, etc.
Amazon.com Wish List
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
