The intersection object creates a shape containing only those areas where all components overlap. A
point is part of an intersection if it is inside both objects, A and B , as show in the
figure below.
The syntax is:
INTERSECTION:
intersection
SOLID_OBJECTS...
[OBJECT_MODIFIERS...]
The component objects must have well defined inside/outside properties. Patch objects are not allowed.
Note: if all components do not overlap, the intersection object disappears.
Here is an example that overlaps:
intersection {
box { <-1.5, -1, -1>, <0.5, 1, 1> }
cylinder { <0.5, 0, -1>, <0.5, 0, 1>, 1 }
