POV-Ray : Documentation : 2.3.1 Camera
  POV-Ray 3.6 Documentation Online View
2.3 Scene Settings   2.3.1.1 Placing the Camera
2.3.1 Camera
The camera definition describes the position, projection type and properties of the camera viewing the scene. Its syntax is:
CAMERA:
    camera{ [CAMERA_ITEMS...] }
CAMERA_ITEM:
    CAMERA_TYPE | CAMERA_VECTOR | CAMERA_MODIFIER |
    CAMERA_IDENTIFIER
CAMERA_TYPE:
    perspective | orthographic | fisheye | ultra_wide_angle |
    omnimax | panoramic | cylinder CylinderType | spherical
CAMERA_VECTOR:
    location <Location> | right <Right> | up <Up> |
    direction <Direction> | sky <Sky>
CAMERA_MODIFIER:
    angle HORIZONTAL [VERTICAL] | look_at <Look_At> |
    blur_samples Num_of_Samples | aperture Size |
    focal_point <Point> | confidence Blur_Confidence |
    variance Blur_Variance | NORMAL | TRANSFORMATION
Camera default values:
DEFAULT CAMERA:
    perspective
    location <0,0,0>
    direction <0,0,1>
    right 1.33*x
    up y
    sky <0,1,0>
CAMERA TYPE: perspective
angle      : ~67.380 ( direction_length=0.5*
                       right_length/tan(angle/2) )
confidence : 0.9 (90%)
direction  : <0,0,1>
focal_point: <0,0,0>
look_at    : z
right      : 1.33*x
sky        : <0,1,0>
up         : y
variance   : 1/128
Depending on the projection type zero or more of the parameters are required:
  • If no camera is specified the default camera is used.
  • If no projection type is given the perspective camera will be used (pinhole camera).
  • The CAMERA_TYPE has to be the first item in the camera statement.
  • Other CAMERA_ITEMs may legally appear in any order.
  • For other than the perspective camera, the minimum that has to be specified is the CAMERA_TYPE, the cylindrical camera also requires the CAMERA_TYPE to be followed by a float.
  • The Orthographic camera has two 'modes'. For the pure orthographic projection up or right have to be specified. For an orthographic camera, with the same area of view as a perspective camera at the plane which goes through the look_at point, the angle keyword has to be use. A value for the angle is optional.
  • All other CAMERA_ITEMs are taken from the default camera, unless they are specified differently.
Amazon.com Wish List
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
