2.1.2.3 Display Output Options
2.1.2.3.1 Display Hardware Settings
Display=bool
Turns graphic display on/off
+D
-D
Turns graphic display off
Video_Mode=x
Set video mode to x; does not affect on/off
+Dx
Set display on; Set mode to x
-Dx
Set display off; but for future use mode x
Palette=y
Set display palette to y; does not affect on/off
+Dxy
Set display on; Set mode x; Set palette y
-Dxy
Set display off; use mode x, palette y in future
Display_Gamma=n.n
Sets the display gamma to n.n
The Display=on or +D switch will turn on the graphics display of the image while it is
being rendered. Even on some non-graphics systems, POV-Ray may display an 80 by 24 character "ASCII-Art"
version of your image. Where available, the display may be full, 24-bit true color. Setting Display=off
or using the -D switch will turn off the graphics display which is the default.
On the Windows platform, the default is Display=on. Turning display off does not, of course, turn off
the actual video display. Instead, POV-Ray will not open the output window that it normally shows a render in.
The Video_Mode=x option sets the display mode or hardware type chosen where x is a
single digit or letter that is machine dependent. Generally Video_Mode=0 means the default or an
auto-detected setting should be used. When using switches, this character immediately follows the switch. For example
the +D0 switch will turn on the graphics display in the default mode.
The Palette=y option selects the palette to be used. Typically the single character
parameter y is a digit which selects one of several fixed palettes or a letter such G for gray
scale, H for 15-bit or 16-bit high color or T for 24-bit true color. When using switches,
this character is the 2nd character after the switch. For example the +D0T switch will turn on the
graphics display in the default mode with a true color palette. The Display_Gamma=n.n setting
is not available as a command-line switch.
The Display_Gamma setting overcomes the problem of images (whether ray-traced or not) having
different brightness when being displayed on different monitors, different video cards, and under different operating
systems.
Note: the Display_Gamma is a setting based on your computer's display
hardware, and should be set correctly once and not changed.
The Display_Gamma INI setting works in conjunction with the new assumed_gamma global
setting to ensure that POV scenes and the images they create look the same on all systems. See section "Assumed_Gamma"
which describes the assumed_gamma global setting and describes gamma more thoroughly.
While the Display_Gamma can be different for each system, there are a few general rules that can be
used for setting Display_Gamma if you do not know it exactly. If the Display_Gamma keyword
does not appear in the INI file, POV-Ray assumes that the display gamma is 2.2. This is because most PC monitors have
a gamma value in the range 1.6 to 2.6 (newer models seem to have a lower gamma value). Mac has the ability to do gamma
correction inside the system software (based on a user setting in the gamma control panel). If the gamma control panel
is turned off, or is not available, the default Macintosh system gamma is 1.8. Many newer PC graphics cards can do
hardware gamma correction and should use the current Display_Gamma setting, usually 1.0.
2.1.2.3.2 Setting your Display Gamma
The following gamma test image can be used to help you set your Display_Gamma accurately.
Before viewing the gamma image darken the room and set the monitor brightness and contrast to maximum. While
viewing a black screen, lower the brightness gradually until the "background" is no longer noticeable (ie
when it just fades from view). This may be difficult on monitors that use overscanning, unless you change the viewable
area settings.
Now, lower the contrast until the alternating white and black bars on the left edge of each column are equal in
width. This is trying to get a 50% gray by using half white and half black. If this is not possible, choose a contrast
setting which is about in the middle. While viewing the image from a distance, or with squinted eyes, one of the
numbered "swatches" will best match the gray value approximated by the white and black bars. The number in
this "swatch" is your display's actual gamma value.
Normal display gamma values are in the range 2.0 to 2.6. If your monitor is usually used in a dim environment, we
often use a gamma value that is 15% - 25% lower than the actual display gamma to give the images more contrast. Some
systems, such as Macs and SGIs, already do gamma correction, so they may have display gammas of 1.0 or 1.8.
For scene files that do not contain an assumed_gamma global setting the INI file option Display_Gamma
will not have any affect on the preview output of POV-Ray or for most output file formats. However, the Display_Gamma
value is used when creating PNG format output files, and also when rendering the POV-Ray example files (because they
have an assumed_gamma), so it should still be correctly set for your system to ensure proper results.
2.1.2.3.3 Display Related Settings
Pause_When_Done=bool
Sets pause when done on/off
+P
-P
Sets pause when done off
Verbose=bool
Set verbose messages on/off
+V
-V
Set verbose messages off
Draw_Vistas=bool
Turn draw vistas on/off
+UD
Turn draw vistas on
-UD
Turn draw vistas off
On some systems, when the image is complete, the graphics display is cleared and POV-Ray switches back into text
mode to print the final statistics and to exit. Normally when the graphics display is on, you want to look at the
image awhile before continuing. Using Pause_When_Done=on or +P causes POV-Ray to pause in
graphics mode until you press a key to continue. The default is not to pause (-P).
When the graphics display is not used, it is often desirable to monitor progress of the rendering. Using
Verbose=on or +V turns on verbose reporting of your rendering progress. This reports the number of
the line currently being rendered, the elapsed time for the current frame and other information. On some systems, this
textual information can conflict with the graphics display. You may need to turn this off when the display is on. The
default setting is off (-V).
The option Draw_Vistas=on or +UD was originally a debugging help for POV-Ray's vista
buffer feature but it was such fun we decided to keep it. Vista buffering is a spatial sub-division method that
projects the 2-D extents of bounding boxes onto the viewing window. POV-Ray tests the 2-D x, y pixel location against
these rectangular areas to determine quickly which objects, if any, the viewing ray will hit. This option shows you
the 2-D rectangles used. The default setting is off (-UD) because the drawing of the rectangles can take
considerable time on complex scenes and it serves no critical purpose. See section "Automatic
Bounding Control" for more details.
Preview_Start_Size=n
Set mosaic preview start size to n
+SPn
Same as Preview_Start_Size=n
Preview_End_Size=n
Set mosaic preview end size to n
+EPn
Same as Preview_End_Size=n
Typically, while you are developing a scene, you will do many low resolution test renders to see if objects are
placed properly. Often this low resolution version does not give you sufficient detail and you have to render the
scene again at a higher resolution. A feature called "mosaic preview" solves this problem by
automatically rendering your image in several passes.
The early passes paint a rough overview of the entire image using large blocks of pixels that look like mosaic
tiles. The image is then refined using higher resolutions on subsequent passes. This display method very quickly
displays the entire image at a low resolution, letting you look for any major problems with the scene. As it refines
the image, you can concentrate on more details, like shadows and textures. You do not have to wait for a full
resolution render to find problems, since you can interrupt the rendering early and fix the scene, or if things look
good, you can let it continue and render the scene at high quality and resolution.
To use this feature you should first select a Width and Height value that is the
highest resolution you will need. Mosaic preview is enabled by specifying how big the mosaic blocks will be on the
first pass using Preview_Start_Size=n or +SPn. The value n should be a
number greater than zero that is a power of two (1, 2, 4, 8, 16, 32, etc.) If it is not a power of two, the nearest
power of two less than n is substituted. This sets the size of the squares, measured in pixels. A value of 16 will
draw every 16th pixel as a 16*16 pixel square on the first pass. Subsequent passes will use half the previous value
(such as 8*8, 4*4 and so on.)
The process continues until it reaches 1*1 pixels or until it reaches the size you set with Preview_End_Size=n
or +EPn. Again the value n should be a number greater than zero that is a power of two and less
than or equal to Preview_Start_Size. If it is not a power of two, the nearest power of two less than n
is substituted. The default ending value is 1. If you set Preview_End_Size to a value greater than 1 the
mosaic passes will end before reaching 1*1, but POV-Ray will always finish with a 1*1. For example, if you want a
single 8*8 mosaic pass before rendering the final image, set Preview_Start_Size=8 and
Preview_End_Size=8.
No file output is performed until the final 1*1 pass is reached. Although the preliminary passes render only as
many pixels as needed, the 1*1 pass re-renders every pixel so that anti-aliasing and file output streams work
properly. This makes the scene take up to 25% longer than the regular 1*1 pass to render, so it is suggested that
mosaic preview not be used for final rendering. Also, the lack of file output until the final pass means that
renderings which are interrupted before the 1*1 pass can not be resumed without starting over from the beginning.
