2.1.2 Command-line Options
  The reference section describes all command line switches and INI file keywords that are used to set the options of
 POV-Ray. It is supposed to be used as a reference for looking up things. It does not contain detailed explanations on
 how scenes are written or how POV-Ray is used. It just explains all features, their syntax, applications, limits,
 drawbacks, etc.
  Options may be specified by switches or INI-style options. Almost all INI-style options have equivalent  +/
 - switches and most switches have equivalent INI-style option. The following sections give a detailed
 description of each POV-Ray option. It includes both the INI-style settings and the  +/ -
 switches.
  The notation and terminology used is described in the tables below.
    Keyword=bool
    Turn Keyword on if bool equals true,  yes, on or 1
   and Turn it off if it is any other value.
    Keyword=true
    Do this option if true, yes,  on or 1 is specified.
    Keyword=false
    Do this option if false, no,  off or 0 is specified.
    Keyword=filename
    Set Keyword to filename where filename is any valid file name.
     Note: some options prohibit the use of any of the above  true or false
    values as a file name. They are noted in later sections.
    n
    Any integer such as in +W320
    n.n
    Any float such as in Clock=3.45
    0.n
    Any float < 1.0 even if it has no leading 0
    s
    Any string of text
    x or y
    Any single character
    path
    Any directory name, drive optional, no final path separator ("\" or "/", depending on the
   operating system)
  Unless otherwise specifically noted, you may assume that either a plus or minus sign before a switch will produce
 the same results.
