1.4.3.3 Can I get a wireframe render of my scene?
  "Is there a way to generate a wireframe output image from a POV scene file?"
  Short answer: No.
  Long answer:
  You have to understand the difference between a modeller like 3D-Studio and POV-Ray in the way they handle objects.
 Those modellers always use triangle meshes (and some modellers use also NURBS which can be very easily converted into
 triangles). Triangle meshes are extremely simple to represent in a wireframe format: Just draw a line for each
 triangle side.
  However, POV-Ray handles most of the objects as mathematical entities, not triangle meshes. When you tell POV-Ray
 to create a sphere, POV-Ray only handles it as a point and a radius, nothing else (besides the possible matrix
 transform applied to it). POV-Ray only has a notion of the shape of the object as a mathematical formula (it can
 calculate the intersection of a line and the sphere).
  For wireframe output there should be a way to convert that mathematical representation of the object into actual
 triangles. This is called tesselation.
  For some mathematical objects, like the sphere, the box, etc, tesselation is quite trivial. For other entities,
 like CSG difference, intersection, etc, it is more difficult (although not impossible). For other entities it is
 completely impossible: infinite non-flat surfaces like paraboloids and hyperboloids (well, actually it is possible if
 you limit the size of the surface to a finite shape; still the amount of triangles that needs to be created would be
 extremely high).
  There have been lots of discussions about incorporating tesselation into POV-Ray. But since POV-Ray is just a
 renderer, not a modeller, it does not seem to be worth the efforts (adding tesselation to all the primitives and CSG
 would be a huge job).
  (Of course tesselation could give some other advantages, like the ability to fake non-uniform transformations to
 objects like most triangle mesh modellers do...)
  If you just want fast previews of the image, you can try to use the quality parameter of POV-Ray. For example
 setting quality to 0 (+q0) can give a very fast render. See also the rendering speed question.
More about "the rendering speed question"
