|  |  | 1.4.1.10 How can I fill a glass with water or other objects?
  As described in the "hollow objects" question above, hollow objects have always two surfaces: an outer
 surface and an inner surface. If we take the same example, a simple glass would be like:
// A simple water glass made with a difference:
#declare MyGlass=
difference
{ cone { <0,0,0>,1,<0,5,0>,1.2 }
  cone { <0,.1,0>,.9,<0,5.1,0>,1.1 }
  texture { Glass }
  The first cone limits the outer surface of the glass and the second cone limits the inner surface.
  If we want to fill the glass with water, we have to make an object which coincides with the inner surface of the
 glass. Note that you have to avoid the coincident surfaces problem so you
 should scale the "water" object just a little bit smaller than the inner surface of the glass. So we make
 something like this:
#declare MyGlassWithWater=
union
{ object { MyGlass }
  cone
    scale .999
    texture { Water }
  Now the glass is filled with water. But there is one problem: There is too much water. The glass should be filled
 only up to certain level, which should be definable. Well, this can be easily made with a CSG operation:
union
  intersection
  { cone { <0,.1,0>,.9,<0,5.1,0>,1.1 }
    plane { y,4 }
    scale .999
    texture { Water }
  Now the water level is at a height of 4 units.
