1.3.8.3 The Phase Keyword
There is another keyword we should know for purposes of animations: the phase
keyword. The phase keyword can be used on many texture elements, especially those that can take a color, pigment,
normal or texture map. Remember the form that these maps take. For example:
color_map {
[0.00 White ]
[0.25 Blue ]
[0.76 Green ]
[1.00 Red ]
The floating point value to the left inside each set of brackets helps POV-Ray to map the color values to various
areas of the object being textured. Notice that the map runs cleanly from 0.0 to 1.0?
Phase causes the color values to become shifted along the map by a floating point value which follows the keyword phase .
Now, if we are using a normalized clock value already anyhow, we can make the variable clock the floating point value
associated with phase, and the pattern will smoothly shift over the course of the animation. Let's look at a common
example using a gradient normal pattern
#include "textures.inc"
background { rgb<0.8, 0.8, 0.8> }
location <1.5, 1, -30>
look_at <0, 1, 0>
angle 10
light_source { <-100, 20, -100> color White }
// flag
polygon {
5, <0, 0>, <0, 1>, <1, 1>, <1, 0>, <0, 0>
pigment { Blue }
normal {
gradient x
phase clock
scale <0.2, 1, 1>
sine_wave
scale <3, 2, 1>
translate <-1.5, 0, 0>
// flagpole
cylinder {
<-1.5, -4, 0>, <-1.5, 2.25, 0>, 0.05
texture { Silver_Metal }
// polecap
sphere {
<-1.5, 2.25, 0>, 0.1
Now, here we have created a simple blue flag with a gradient normal pattern on it. We have forced the gradient to
use a sine-wave type wave so that it looks like the flag is rolling back and forth as though flapping in a breeze. But
the real magic here is that phase keyword. It has been set to take the clock variable as a floating point value which,
as the clock increments slowly toward 1.0, will cause the crests and troughs of the flag's wave to shift along the
x-axis. Effectively, when we animate the frames created by this code, it will look like the flag is actually rippling
in the wind.
This is only one, simple example of how a clock dependant phase shift can create interesting animation effects.
Trying phase will all sorts of texture patterns, and it is amazing the range of animation effects we can create simply
by phase alone, without ever actually moving the object.
