Whenever you open the context menu, the editor first looks underneath the edit caret to see if there is a line that
looks like a POV-Ray scene file '#include' directive. If one is found, the name of the specified file is placed into
the menu in place of "filename". If one is not found, then it may show "Copy ... to Command-Line"
(see below).
If you then select this command, the editor will attempt to find and open the file in a new edit window. The
standard include paths (as defined in PVENGINE.INI) will be searched if the file is not found relative to the current
directory.
