3.5.6.4 Adding a Separator
Creating a special file called '-.txt' (a hyphen followed by .txt) usually prefixed by a 'NN
- ' (e.g. '30 - -.txt'), will cause a menu separator to be drawn instead of inserting a new item
into the menu. The contents of the file are ignored.
To create a separator between sub-menus, do the same thing as above, but create a folder instead of a file and
leave off the '.txt' extension.
