POV-Ray : Documentation : 2.5.11.5 Brick
  POV-Ray 3.6 Documentation Online View
2.5.11.4 Bozo   2.5.11.6 Bumps
2.5.11.5 Brick
The brick pattern generates a pattern of bricks. The bricks are offset by half a brick length on every other row in the x- and z-directions. A layer of mortar surrounds each brick. The syntax is given by
   brick COLOR_1, COLOR_2
   [brick_size <Size>] [mortar Size]
where COLOR_1 is the color of the mortar and COLOR_2 is the color of the brick itself. If no colors are specified a default deep red and dark gray are used. The default size of the brick and mortar together is <8, 3, 4.5> units. The default thickness of the mortar is 0.5 units. These values may be changed using the optional brick_size and mortar pattern modifiers. You may also use pigment statements in place of the colors. For example:
    brick pigment{Jade}, pigment{Black_Marble}
This example uses normals:
  normal { brick 0.5 }
The float value is an optional bump size. You may also use full normal statements. For example:
  normal {
    brick normal{bumps 0.2}, normal{granite 0.3}
When used with textures, the syntax is
    brick texture{T_Gold_1A}, texture{Stone12}
This is a block pattern which cannot use wave types, color_map, or slope_map modifiers.
The brick pattern has a default color_map built in that results in red bricks and grey mortar.
Copyright 2003-2021 Persistence of Vision Raytracer Pty. Ltd.
