Highlights are the bright spots that appear when a light source reflects off of a smooth object. They are a blend
of specular reflection and diffuse reflection. They are specular-like because they depend upon viewing angle and
illumination angle. However they are diffuse-like because some scattering occurs. In order to exactly model a
highlight you would have to calculate specular reflection off of thousands of microscopic bumps called micro facets.
The more that micro facets are facing the viewer the shinier the object appears and the tighter the highlights become.
POV-Ray uses two different models to simulate highlights without calculating micro facets. They are the specular
and Phong models.
Note: specular and Phong highlights are not mutually exclusive. It is
possible to specify both and they will both take effect. Normally, however, you will only specify one or the other.
The phong keyword in the finish statement controls the amount of Phong highlighting on
the object. It causes bright shiny spots on the object that are the color of the light source being reflected.
The Phong method measures the average of the facets facing in the mirror direction from the light sources to the
viewer.
Phong's value is typically from 0.0 to 1.0, where 1.0 causes complete saturation to the light source's color at the
brightest area (center) of the highlight. The default phong 0.0 gives no highlight.
The size of the highlight spot is defined by the phong_size value. The larger the phong size the
tighter, or smaller, the highlight and the shinier the appearance. The smaller the phong size the looser, or larger,
the highlight and the less glossy the appearance.
Typical values range from 1.0 (very dull) to 250 (highly polished) though any values may be used. Default phong
size is 40 (plastic) if phong_size is not specified. For example:
finish { phong 0.9 phong_size 60 }
If phong is not specified phong_size has no effect.
2.5.3.3.2 Specular Highlight
The specular keyword in a finish statement produces a highlight which is very similar to
Phong highlighting but it uses slightly different model. The specular model more closely resembles real specular
reflection and provides a more credible spreading of the highlights occurring near the object horizons.
The specular value is typically from 0.0 to 1.0, where 1.0 causes complete saturation to the light source's color
at the brightest area (center) of the highlight. The default specular 0.0 gives no highlight.
The size of the spot is defined by the value given the
roughness keyword. Typical values range from 1.0 (very rough - large highlight) to 0.0005 (very smooth - small
highlight). The default value, if roughness is not specified, is 0.05 (plastic).
It is possible to specify wrong values for roughness that will generate an error when you try to render the file.
Do not use 0 and if you get errors check to see if you are using a very, very small roughness value that may be
causing the error. For example:
finish { specular 0.9 roughness 0.02 }
If specular is not specified roughness has no effect.
Note: that when light is reflected by a surface such as a mirror, it is called specular
reflection however such reflection is not controlled by the specular keyword. The reflection
keyword controls mirror-like specular reflection.
2.5.3.3.3 Metallic Highlight Modifier
The keyword metallic may be used with phong or specular highlights. This
keyword indicates that the color of the highlights will be calculated by an empirical function that models the
reflectivity of metallic surfaces.
Normally highlights are the color of the light source. Adding this keyword filters the highlight so that white
light reflected from a metallic surface takes the color specified by the pigment
The metallic keyword may optionally be follow by a numeric value to specify the influence the amount
of the effect. If no keyword is specified, the default value is zero. If the keyword is specified without a value, the
default value is one. For example:
finish {
phong 0.9
phong_size 60
metallic
If phong or specular keywords are not specified then metallic has no effect.
