POV-Ray : Documentation : 2.7.7.2 Internal Functions
  POV-Ray 3.6 Documentation Online View
2.7.7.1 Common Parameters   2.7.7.3 Pre defined functions
Here is a list of the internal functions in the order they appear in the "functions.inc" include file
f_algbr_cyl1(x,y,z, P0, P1, P2, P3, P4). An algebraic cylinder is what you get if you take any 2d curve and plot it in 3d. The 2d curve is simply extruded along the third axis, in this case the z axis.
With the SOR Switch switched on, the figure-of-eight curve will be rotated around the Y axis instead of being extruded along the Z axis.
f_algbr_cyl2(x,y,z, P0, P1, P2, P3, P4). An algebraic cylinder is what you get if you take any 2d curve and plot it in 3d. The 2d curve is simply extruded along the third axis, in this case the z axis.
With the SOR Switch switched on, the cross section curve will be rotated around the Y axis instead of being extruded along the Z axis.
f_algbr_cyl3(x,y,z, P0, P1, P2, P3, P4). An algebraic cylinder is what you get if you take any 2d curve and plot it in 3d. The 2d curve is simply extruded along the third axis, in this case the Z axis.
f_algbr_cyl4(x,y,z, P0, P1, P2, P3, P4). An algebraic cylinder is what you get if you take any 2d curve and plot it in 3d. The 2d curve is simply extruded along the third axis, in this case the z axis.
f_bicorn(x,y,z, P0, P1). The surface is a surface of revolution.
  • P0 : Field Strength (Needs a negative field strength or a negated function)
  • P1 : Scale. The mathematics of this surface suggest that the shape should be different for different values of this parameter. In practice the difference in shape is hard to spot. Setting the scale to 3 gives a surface with a radius of about 1 unit
f_bifolia(x,y,z, P0, P1). The bifolia surface looks something like the top part of a a paraboloid bounded below by another paraboloid.
  • P1 : Scale. The surface is always the same shape. Changing this parameter has the same effect as adding a scale modifier. Setting the scale to 1 gives a surface with a radius of about 1 unit
f_blob(x,y,z, P0, P1, P2, P3, P4). This function generates blobs that are similar to a CSG blob with two spherical components. This function only seems to work with negative threshold settings.
  • P0 : X distance between the two components
  • P1 : Blob strength of component 1
  • P2 : Inverse blob radius of component 1
  • P3 : Blob strength of component 2
  • P4 : Inverse blob radius of component 2
f_blob2(x,y,z, P0, P1, P2, P3). The surface is similar to a CSG blob with two spherical components.
  • P0 : Separation. One blob component is at the origin, and the other is this distance away on the X axis
  • P1 : Inverse size. Increase this to decrease the size of the surface
  • P2 : Blob strength
  • P3 : Threshold. Setting this parameter to 1 and the threshold to zero has exactly the same effect as setting this parameter to zero and the threshold to -1
f_boy_surface(x,y,z, P0, P1). For this surface, it helps if the field strength is set low, otherwise the surface has a tendency to break up or disappear entirely. This has the side effect of making the rendering times extremely long.
f_comma(x,y,z, P0). The 'comma' surface is very much like a comma-shape.
  • P0 : Scale
f_cross_ellipsoids(x,y,z, P0, P1, P2, P3). The 'cross ellipsoids' surface is like the union of three crossed ellipsoids, one oriented along each axis.
  • P0 : Eccentricity. When less than 1, the ellipsoids are oblate, when greater than 1 the ellipsoids are prolate, when zero the ellipsoids are spherical (and hence the whole surface is a sphere)
  • P2 : Diameter. Increase this to increase the size of the ellipsoids
f_crossed_trough(x,y,z, P0)
f_cubic_saddle(x,y,z, P0). For this surface, it helps if the field strength is set quite low, otherwise the surface has a tendency to break up or disappear entirely.
f_cushion(x,y,z, P0)
f_devils_curve(x,y,z, P0)
f_devils_curve_2d(x,y,z, P0, P1, P2, P3, P4, P5). The f_devils_curve_2d curve can be extruded along the z axis, or using the SOR parameters it can be made into a surface of revolution. The X and Y factors control the size of the central feature.
f_dupin_cyclid(x,y,z, P0, P1, P2, P3, P4, P5)
  • P1 : Major radius of torus
  • P2 : Minor radius of torus
  • P3 : X displacement of torus
  • P4 : Y displacement of torus
  • P5 : Radius of inversion
f_ellipsoid(x,y,z, P0, P1, P2). f_ellipsoid generates spheres and ellipsoids. Needs "threshold 1".
Setting these scaling parameters to 1/n gives exactly the same effect as performing a scale operation to increase the scaling by n in the corresponding direction.
  • P0 : X scale (inverse)
  • P1 : Y scale (inverse)
  • P2 : Z scale (inverse)
f_enneper(x,y,z, P0)
f_flange_cover(x,y,z, P0, P1, P2, P3)
  • P0 : Spikiness. Set this to very low values to increase the spikes. Set it to 1 and you get a sphere
  • P1 : Inverse size. Increase this to decrease the size of the surface. (The other parameters also drastically affect the size, but this parameter has no other effects)
  • P2 : Flange. Increase this to increase the flanges that appear between the spikes. Set it to 1 for no flanges
f_folium_surface(x,y,z, P0, P1, P2). A 'folium surface' looks something like a paraboloid glued to a plane.
  • P1 : Neck width factor - the larger you set this, the narrower the neck where the paraboloid meets the plane
  • P2 : Divergence - the higher you set this value, the wider the paraboloid gets
f_folium_surface_2d(x,y,z, P0, P1, P2, P3, P4, P5). The f_folium_surface_2d curve can be rotated around the X axis to generate the same 3d surface as the f_folium_surface, or it can be extruded in the Z direction (by switching the SOR switch off)
  • P1 : Neck width factor - same as the 3d surface if you are revolving it around the Y axis
  • P2 : Divergence - same as the 3d surface if you are revolving it around the Y axis
  • P3 : SOR Switch
  • P4 : SOR Offset
  • P5 : SOR Angle
f_glob(x,y,z, P0). One part of this surface would actually go off to infinity if it were not restricted by the contained_by shape.
f_heart(x,y,z, P0)
f_helical_torus(x,y,z, P0, P1, P2, P3, P4, P5, P6, P7, P8, P9). With some sets of parameters, it looks like a torus with a helical winding around it. The winding optionally has grooves around the outside.
  • P0 : Major radius
  • P1 : Number of winding loops
  • P2 : Twistiness of winding. When zero, each winding loop is separate. When set to one, each loop twists into the next one. When set to two, each loop twists into the one after next
  • P3 : Fatness of winding?
  • P4 : Threshold. Setting this parameter to 1 and the threshold to zero has s similar effect as setting this parameter to zero and the threshold to 1
  • P5 : Negative minor radius? Reducing this parameter increases the minor radius of the central torus. Increasing it can make the torus disappear and be replaced by a vertical column. The value at which the surface switches from one form to the other depends on several other parameters
  • P6 : Another fatness of winding control?
  • P7 : Groove period. Increase this for more grooves
  • P8 : Groove amplitude. Increase this for deeper grooves
  • P9 : Groove phase. Set this to zero for symmetrical grooves
f_helix1(x,y,z, P0, P1, P2, P3, P4, P5, P6)
  • P0 : Number of helixes - e.g. 2 for a double helix
  • P1 : Period - is related to the number of turns per unit length
  • P2 : Minor radius (major radius > minor radius)
  • P3 : Major radius
  • P4 : Shape parameter. If this is greater than 1 then the tube becomes fatter in the y direction
  • P5 : Cross section type
  • P6 : Cross section rotation angle (degrees)
f_helix2(x,y,z, P0, P1, P2, P3, P4, P5, P6). Needs a negated function
  • P0 : Not used
  • P2 : Minor radius (minor radius > major radius)
  • P3 : Major radius
  • P4 : Not used
f_hex_x(x,y,z, P0). This creates a grid of hexagonal cylinders stretching along the z-axis. The fatness is controlled by the threshold value. When this value equals 0.8660254 or cos(30) the sides will touch, because this is the distance between centers. Negating the function will inverse the surface and create a honey-comb structure. This function is also useful as pigment function.
  • P0 : No effect (but the syntax requires at least one parameter)
f_hex_y(x,y,z, P0). This is function forms a lattice of infinite boxes stretching along the z-axis. The fatness is controlled by the threshold value. These boxes are rotated 60 degrees around centers, which are 0.8660254 or cos(30) away from each other. This function is also useful as pigment function.
f_hetero_mf(x,y,z, P0, P1, P2, P3, P4, P5). f_hetero_mf (x,0,z) makes multifractal height fields and patterns of '1/f' noise
'Multifractal' refers to their characteristic of having a fractal dimension which varies with altitude. Built from summing noise of a number of frequencies, the hetero_mf parameters determine how many, and which frequencies are to be summed.
An advantage to using these instead of a height_field {} from an image (a number of height field programs output multifractal types of images) is that the hetero_mf function domain extends arbitrarily far in the x and z directions so huge landscapes can be made without losing resolution or having to tile a height field. Other functions of interest are f_ridged_mf and f_ridge.
  • P0 : H is the negative of the exponent of the basis noise frequencies used in building these functions (each frequency f's amplitude is weighted by the factor f - H ). In landscapes, and many natural forms, the amplitude of high frequency contributions are usually less than the lower frequencies.
    When H is 1, the fractalization is relatively smooth ("1/f noise").
    As H nears 0, the high frequencies contribute equally with low frequencies as in "white noise".
  • P1 : Lacunarity' is the multiplier used to get from one 'octave' to the next. This parameter affects the size of the frequency gaps in the pattern. Make this greater than 1.0
  • P2 : Octaves is the number of different frequencies added to the fractal. Each 'Octave' frequency is the previous one multiplied by 'Lacunarity', so that using a large number of octaves can get into very high frequencies very quickly.
  • P3 : Offset is the 'base altitude' (sea level) used for the heterogeneous scaling
  • P4 : T scales the 'heterogeneity' of the fractal. T=0 gives 'straight 1/f' (no heterogeneous scaling). T=1 suppresses higher frequencies at lower altitudes
  • P5 : Generator type used to generate the noise3d. 0, 1, 2 and 3 are legal values.
f_hunt_surface(x,y,z, P0)
f_hyperbolic_torus(x,y,z, P0, P1, P2)
  • P1 : Major radius: separation between the centers of the tubes at the closest point
  • P2 : Minor radius: thickness of the tubes at the closest point
f_isect_ellipsoids(x,y,z, P0, P1, P2, P3). The 'isect ellipsoids' surface is like the intersection of three crossed ellipsoids, one oriented along each axis.
f_kampyle_of_eudoxus(x,y,z, P0, P1, P2). The 'kampyle of eudoxus' is like two infinite planes with a dimple at the center.
  • P1 : Dimple: When zero, the two dimples punch right through and meet at the center. Non-zero values give less dimpling
  • P2 : Closeness: Higher values make the two planes become closer
f_kampyle_of_eudoxus_2d(x,y,z, P0, P1, P2, P3, P4, P5)The 2d curve that generates the above surface can be extruded in the Z direction or rotated about various axes by using the SOR parameters.
  • P3 : SOR Switch
  • P4 : SOR Offset
  • P5 : SOR Angle
f_klein_bottle(x,y,z, P0)
f_kummer_surface_v1(x,y,z, P0). The Kummer surface consists of a collection of radiating rods.
f_kummer_surface_v2(x,y,z, P0, P1, P2, P3). Version 2 of the kummer surface only looks like radiating rods when the parameters are set to particular negative values. For positive values it tends to look rather like a superellipsoid.
  • P1 : Rod width (negative): Setting this parameter to larger negative values increases the diameter of the rods
  • P2 : Divergence (negative): Setting this number to -1 causes the rods to become approximately cylindrical. Larger negative values cause the rods to become fatter further from the origin. Smaller negative numbers cause the rods to become narrower away from the origin, and have a finite length
  • P3 : Influences the length of half of the rods. Changing the sign affects the other half of the rods. 0 has no effect
f_lemniscate_of_gerono(x,y,z, P0). The "Lemniscate of Gerono" surface is an hourglass shape. Two teardrops with their ends connected.
f_lemniscate_of_gerono_2d(x,y,z, P0, P1, P2, P3, P4, P5). The 2d version of the Lemniscate can be extruded in the Z direction, or used as a surface of revolution to generate the equivalent of the 3d version, or revolved in different ways.
  • P1 : Size: increasing this makes the 2d curve larger and less rounded
  • P2 : Width: increasing this makes the 2d curve fatter
  • P3 : SOR Switch
  • P4 : SOR Offset
  • P5 : SOR Angle
f_mesh1(x,y,z, P0, P1, P2, P3, P4) The overall thickness of the threads is controlled by the isosurface threshold, not by a parameter. If you render a mesh1 with zero threshold, the threads have zero thickness and are therefore invisible. Parameters P2 and P4 control the shape of the thread relative to this threshold parameter.
  • P0 : Distance between neighboring threads in the x direction
  • P1 : Distance between neighboring threads in the z direction
  • P2 : Relative thickness in the x and z directions
  • P3 : Amplitude of the weaving effect. Set to zero for a flat grid
  • P4 : Relative thickness in the y direction
f_mitre(x,y,z, P0). The 'Mitre' surface looks a bit like an ellipsoid which has been nipped at each end with a pair of sharp nosed pliers.
f_nodal_cubic(x,y,z, P0). The 'Nodal Cubic' is something like what you would get if you were to extrude the Stophid2D curve along the X axis and then lean it over.
f_noise3d(x,y,z)
f_noise_generator(x,y,z, P0)
  • P0 : Noise generator number
f_odd(x,y,z, P0)
f_ovals_of_cassini(x,y,z, P0, P1, P2, P3). The Ovals of Cassini are a generalization of the torus shape.
  • P1 : Major radius - like the major radius of a torus
  • P2 : Filling. Set this to zero, and you get a torus. Set this to a higher value and the hole in the middle starts to heal up. Set it even higher and you get an ellipsoid with a dimple
  • P3 : Thickness. The higher you set this value, the plumper is the result
f_paraboloid(x,y,z, P0). This paraboloid is the surface of revolution that you get if you rotate a parabola about the Y axis.
f_parabolic_torus(x,y,z, P0, P1, P2)
  • P1 : Major radius
  • P2 : Minor radius
f_ph(x,y,z) = atan2( sqrt( x*x + z*z ), y )
When used alone, the "PH" function gives a surface that consists of all points that are at a particular latitude, i.e. a cone. If you use a threshold of zero (the default) this gives a cone of width zero, which is invisible. Also look at f_th and f_r
f_pillow(x,y,z, P0)
f_piriform(x,y,z, P0). The piriform surface looks rather like half a lemniscate.
f_piriform_2d(x,y,z, P0, P1, P2, P3, P4, P5, P6). The 2d version of the "Piriform" can be extruded in the Z direction, or used as a surface of revolution to generate the equivalent of the 3d version.
  • P1 : Size factor 1: increasing this makes the curve larger
  • P2 : Size factor 2: making this less negative makes the curve larger but also thinner
  • P3 : Fatness: increasing this makes the curve fatter
  • P4 : SOR Switch
  • P5 : SOR Offset
  • P6 : SOR Angle
f_poly4(x,y,z, P0, P1, P2, P3, P4). This f_poly4 can be used to generate the surface of revolution of any polynomial up to degree 4.
To put it another way: If we call the parameters A, B, C, D, E; then this function generates the surface of revolution formed by revolving "x = A + By + Cy2 + Dy3 + Ey4" around the Y axis.
  • P0 : Constant
  • P1 : Y coefficient
  • P2 : Y2 coefficient
  • P3 : Y3 coefficient
  • P4 : Y4 coefficient
f_polytubes(x,y,z, P0, P1, P2, P3, P4, P5). The 'Polytubes' surface consists of a number of tubes. Each tube follows a 2d curve which is specified by a polynomial of degree 4 or less. If we look at the parameters, then this function generates "P0" tubes which all follow the equation " x = P1 + P2y + P3y2 + P4y3 + P5y4 " arranged around the Y axis.
This function needs a positive threshold (fatness of the tubes).
  • P0 : Number of tubes
  • P1 : Constant
  • P2 : Y coefficient
  • P3 : Y2 coefficient
  • P4 : Y3 coefficient
  • P5 : Y4 coefficient
f_quantum(x,y,z, P0). It resembles the shape of the electron density cloud for one of the d orbitals.
  • P0 : Not used, but required
f_quartic_paraboloid(x,y,z, P0). The 'Quartic Paraboloid' is similar to a paraboloid, but has a squarer shape.
f_quartic_saddle(x,y,z, P0). The 'Quartic saddle' is similar to a saddle, but has a squarer shape.
f_quartic_cylinder(x,y,z, P0, P1, P2). The 'Quartic cylinder' looks a bit like a cylinder that is swallowed an egg.
  • P1 : Diameter of the "egg"
  • P2 : Controls the width of the tube and the vertical scale of the "egg"
f_r(x,y,z) = sqrt( x*x + y*y + z*z )
When used alone, the "R" function gives a surface that consists of all the points that are a specific distance (threshold value) from the origin, i.e. a sphere. Also look at f_ph and f_th
f_ridge(x,y,z, P0, P1, P2, P3, P4, P5). This function is mainly intended for modifying other surfaces as you might use a height field or to use as pigment function. Other functions of interest are f_hetero_mf and f_ridged_mf.
  • P0 : Lambda
  • P1 : Octaves
  • P2 : Omega
  • P3 : Offset
  • P4 : Ridge
f_ridged_mf(x,y,z, P0, P1, P2, P3, P4, P5). The "Ridged Multifractal" surface can be used to create multifractal height fields and patterns. 'Multifractal' refers to their characteristic of having a fractal dimension which varies with altitude. They are built from summing noise of a number of frequencies. The f_ridged_mf parameters determine how many, and which frequencies are to be summed, and how the different frequencies are weighted in the sum.
An advantage to using these instead of a height_field{} from an image is that the ridged_mf function domain extends arbitrarily far in the x and z directions so huge landscapes can be made without losing resolution or having to tile a height field. Other functions of interest are f_hetero_mf and f_ridge.
  • P0 : H is the negative of the exponent of the basis noise frequencies used in building these functions (each frequency f's amplitude is weighted by the factor fE- H ). When H is 1, the fractalization is relatively smooth. As H nears 0, the high frequencies contribute equally with low frequencies
  • P1 : Lacunarity is the multiplier used to get from one "octave" to the next in the "fractalization".
    This parameter affects the size of the frequency gaps in the pattern. (Use values greater than 1.0)
  • P2 : Octaves is the number of different frequencies added to the fractal. Each octave frequency is the previous one multiplied by "Lacunarity". So, using a large number of octaves can get into very high frequencies very quickly
  • P3 : Offset gives a fractal whose fractal dimension changes from altitude to altitude. The high frequencies at low altitudes are more damped than at higher altitudes, so that lower altitudes are smoother than higher areas
  • P4 : Gain weights the successive contributions to the accumulated fractal result to make creases stick up as ridges
f_rounded_box(x,y,z, P0, P1, P2, P3). The Rounded Box is defined in a cube from <-1, -1, -1> to <1, 1, 1>. By changing the " Scale" parameters, the size can be adjusted, without affecting the Radius of curvature.
  • P0 : Radius of curvature. Zero gives square corners, 0.1 gives corners that match "sphere {0, 0.1}"
  • P1 : Scale x
  • P2 : Scale y
  • P3 : Scale z
f_sphere(x,y,z, P0)
  • P0: radius of the sphere
f_spikes(x,y,z, P0, P1, P2, P3, P4)
  • P1 : Hollowness. Increasing this causes the sides to bend in more
  • P2 : Size. Increasing this increases the size of the object
  • P3 : Roundness. This parameter has a subtle effect on the roundness of the spikes
  • P4 : Fatness. Increasing this makes the spikes fatter
f_spikes_2d(x,y,z, P0, P1, P2, P3) =2-D function : f = f( x, z ) - y
  • P0 : Height of central spike
  • P1 : Frequency of spikes in the X direction
  • P2 : Frequency of spikes in the Z direction
  • P3 : Rate at which the spikes reduce as you move away from the center
f_spiral(x,y,z, P0, P1, P2, P3, P4, P5)
  • P0 : Distance between windings
  • P1 : Thickness
  • P2 : Outer diameter of the spiral. The surface behaves as if it is contained_by a sphere of this diameter
  • P3 : Not used
  • P4 : Not used
f_steiners_roman(x,y,z, P0). The "Steiners Roman" is composed of four identical triangular pads which together make up a sort of rounded tetrahedron. There are creases along the X, Y and Z axes where the pads meet.
f_strophoid(x,y,z, P0, P1, P2, P3). The "Strophoid" is like an infinite plane with a bulb sticking out of it.
  • P1 : Size of bulb. Larger values give larger bulbs. Negative values give a bulb on the other side of the plane
  • P2 : Sharpness. When zero, the bulb is like a sphere that just touches the plane. When positive, there is a crossover point. When negative the bulb simply bulges out of the plane like a pimple
  • P3 : Flatness. Higher values make the top end of the bulb fatter
f_strophoid_2d(x,y,z, P0, P1, P2, P3, P4, P5, P6). The 2d strophoid curve can be extruded in the Z direction or rotated about various axes by using the SOR parameters.
  • P3 : Fatness. Higher values make the top end of the bulb fatter
  • P4 : SOR Switch
  • P5 : SOR Offset
  • P6 : SOR Angle
f_superellipsoid(x,y,z, P0, P1). Needs a negative field strength or a negated function.
  • P0 : east-west exponentx
  • P1 : north-south exponent
f_th(x,y,z) = atan2( x, z )
f_th() is a function that is only useful when combined with other surfaces.
It produces a value which is equal to the "theta" angle, in radians, at any point. The theta angle is like the longitude coordinate on the Earth. It stays the same as you move north or south, but varies from east to west. Also look at f_ph and f_r
f_torus(x,y,z, P0, P1)
  • P0 : Major radius
  • P1 : Minor radius
f_torus2(x,y,z, P0, P1, P2). This is different from the f_torus function which just has the major and minor radii as parameters.
  • P1 : Major radius
  • P2 : Minor radius
f_torus_gumdrop(x,y,z, P0). The "Torus Gumdrop" surface is something like a torus with a couple of gumdrops hanging off the end.
f_umbrella(x,y,z, P0)
f_witch_of_agnesi(x,y,z, P0, P1, P2, P3, P4, P5). The "Witch of Agnesi" surface looks something like a witches hat.
  • P1 : Controls the width of the spike. The height of the spike is always about 1 unit
f_witch_of_agnesi_2d(x,y,z, P0, P1, P2, P3, P4, P5). The 2d version of the "Witch of Agnesi" curve can be extruded in the Z direction or rotated about various axes by use of the SOR parameters.
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
