POV-Ray : Documentation : 2.7.11.1 Flat Distributions
  POV-Ray 3.6 Documentation Online View
2.7.11 rand.inc   2.7.11.2 Other Distributions
SRand(Stream). "Signed rand()", returns random numbers in the range [-1, 1].
Parameters:
  • Stream = Random number stream.
RRand(Min, Max, Stream). Returns random numbers in the range [Min, Max].
Parameters:
  • Min = The lower end of the output range.
  • Max = The upper end of the output range.
VRand(Stream). Returns random vectors in a box from < 0, 0, 0> to < 1, 1, 1>
Parameters:
VRand_In_Box(PtA, PtB, Stream). Like VRand(), this macro returns a random vector in a box, but this version lets you specify the two corners of the box.
Parameters:
  • PtA = Lower-left-bottom corner of box.
  • PtB = Upper-right-top corner of box.
VRand_In_Sphere(Stream). Returns a random vector in a unit-radius sphere located at the origin.
Parameters:
VRand_On_Sphere(Stream). Returns a random vector on the surface of a unit-radius sphere located at the origin.
Parameters:
VRand_In_Obj(Object, Stream) This macro takes a solid object and returns a random point that is inside it. It does this by randomly sampling the bounding box of the object, and can be quite slow if the object occupies a small percentage of the volume of its bounding box (because it will take more attempts to find a point inside the object). This macro is best used on finite, solid objects (non-solid objects, such as meshes and bezier patches, do not have a defined "inside", and will not work).
Parameters:
  • Object = The object the macro chooses the points from.
Amazon.com Wish List
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
