POV-Ray : Documentation : 2.5.5 Patterned Textures
  POV-Ray 3.6 Documentation Online View
2.5.4 Halo   2.5.5.1 Texture Maps
Patterned textures are complex textures made up of multiple textures. The component textures may be plain textures or may be made up of patterned textures. A plain texture has just one pigment, normal and finish statement. Even a pigment with a pigment map is still one pigment and thus considered a plain texture as are normals with normal map statements.
Patterned textures use either a texture_map statement to specify a blend or pattern of textures or they use block textures such as checker with a texture list or a bitmap similar to an image map called a material map specified with a material_map statement.
The syntax is...
PATTERNED_TEXTURE:
    texture
        [PATTERNED_TEXTURE_ID]
        [TRANSFORMATIONS...]
    texture
        PATTERN_TYPE
        [TEXTURE_PATTERN_MODIFIERS...]
    texture
        tiles TEXTURE tile2 TEXTURE
    texture
        material_map
            BITMAP_TYPE "bitmap.ext"
            [BITMAP_MODS...] TEXTURE... [TRANSFORMATIONS...]
TEXTURE_PATTERN_MODIFIER:
    PATTERN_MODIFIER | TEXTURE_LIST |
    texture_map { TEXTURE_MAP_BODY }
There are restrictions on using patterned textures. A patterned texture may not be used as a default texture (see section "The #default Directive"). A patterned texture cannot be used as a layer in a layered texture however you may use layered textures as any of the textures contained within a patterned texture.
Amazon.com Wish List
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
