POV-Ray : Documentation : 2.4.9.1 Clipped_By
  POV-Ray 3.6 Documentation Online View
2.4.9 Object Modifiers   2.4.9.2 Bounded_By
2.4.9.1 Clipped_By
The clipped_by statement is technically an object modifier but it provides a type of CSG similar to CSG intersection. The syntax is:
CLIPPED_BY:
    clipped_by { UNTEXTURED_SOLID_OBJECT... } |
    clipped_by { bounded_by }
Where UNTEXTURED_SOLID_OBJECT is one or more solid objects which have had no texture applied. For example:
  object {
    My_Thing
    clipped_by{plane{y,0}}
Every part of the object My_Thing that is inside the plane is retained while the remaining part is clipped off and discarded. In an intersection object the hole is closed off. With clipped_by it leaves an opening. For example the following figure shows object A being clipped by object B.
An object clipped by another object.
You may use clipped_by to slice off portions of any shape. In many cases it will also result in faster rendering times than other methods of altering a shape. Occasionally you will want to use the clipped_by and bounded_by options with the same object. The following shortcut saves typing and uses less memory.
  object {
    My_Thing
    bounded_by { box { <0,0,0>, <1,1,1> } }
This tells POV-Ray to use the same box as a clip that was used as a bound.
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
