POV-Ray : Documentation : 2.3.2.1 Atmospheric Media
  POV-Ray 3.6 Documentation Online View
2.3.2 Atmospheric Effects   2.3.2.2 Background
Atmospheric effects such as fog, dust, haze, or visible gas may be simulated by a media statement specified in the scene but not attached to any object. All areas not inside a non-hollow object in the entire scene. A very simple approach to add fog to a scene is explained in section "Fog" however this kind of fog does not interact with any light sources like media does. It will not show light beams or other effects and is therefore not very realistic.
The atmosphere media effect overcomes some of the fog's limitations by calculating the interaction between light and the particles in the atmosphere using volume sampling. Thus shafts of light beams will become visible and objects will cast shadows onto smoke or fog.
Note: POV-Ray cannot sample media along an infinitely long ray. The ray must be finite in order to be possible to sample. This means that sampling media is only possible for rays that hit an object. So no atmospheric media will show up against background or sky_sphere.
Another way of being able to sample media is using spotlights because also in this case the ray is not infinite (it is sampled only inside the spotlight cone).
With spotlights you will be able to create the best results because their cone of light will become visible. Pointlights can be used to create effects like street lights in fog. Lights can be made to not interact with the atmosphere by adding media_interaction off to the light source. They can be used to increase the overall light level of the scene to make it look more realistic.
Complete details on media are given in the section "Media". Earlier versions of POV-Ray used an atmosphere statement for atmospheric effects but that system was incompatible with the old object halo system. So atmosphere has been eliminated and replaced with a simpler and more powerful media feature. The user now only has to learn one media system for either atmospheric or object use.
If you only want media effects in a particular area, you should use object media rather than only relying upon the media pattern. In general it will be faster and more accurate because it only calculates inside the constraining object.
Note: the atmosphere feature will not work if the camera is inside a non-hollow object (see section "Empty and Solid Objects" for a detailed explanation).
More about "Fog"
More about "media"
More about "Media"
Amazon.com Wish List
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
