An INI file is a text file containing settings for what used to be called POV-Ray command-line options. It replaces
and expands on the functions of the DEF files associated with previous versions of POV-Ray. You can store a default
set of options in the main POV-Ray INI file which is searched for at the following locations:
The place defined by the
POVINI environment variable. When you want to use an INI file at a custom
location you can set this environment variable.
./povray.ini
$HOME/.povray/3.6/povray.ini
PREFIX/etc/povray/3.6/povray.ini (PREFIX by default is /usr/local )
For backwards compatibility with version 3.5, POV-Ray 3.6 also attempts to read the main INI file from the old
locations when none is found at the places above:
$HOME/.povrayrc
PREFIX/etc/povray.ini (PREFIX by default is /usr/local )
Note: Use of these locations is deprecated, they will not be available in future
versions.
Any other INI file can be specified by passing the INI file name on the command line.
One of the options you can set in the INI file is the name of an input file. You can specify the name of a POV file
here. This way you can customize POV-Ray settings for any individual scene file.
For instance, if you have a file called scene.pov, you can create a file scene.ini to contain settings specific for
scene.pov. If you include the option 'Input_File_Name=scene.pov' in scene.ini, and then run povray scene.ini ,
POV-Ray will process scene.pov with the options specified in scene.ini.
Remember, though, that any options set at the command line when you activate an INI file override any corresponding
options in the INI file (see Understanding POV-Ray Options). Also, any
options you do not set in the INI file will be taken as last set by any other INI file or as originally determined in povray.ini .
You can instruct POV-Ray to generate an INI file containing all the options active at the time of rendering. This
way, you can pass a POV file and its associated INI file on to another person and be confident that they will be able
to generate the scene exactly the same way you did. See the section titled Using
INI Files for more information about INI files.
