POV-Ray : Documentation : 2.6.1.3 Scaling objects with an interior
  POV-Ray 3.6 Documentation Online View
2.6.1.2 Empty and Solid Objects   2.6.1.4 Refraction
All the statements that can be put in an interior represent aspects of the matter that an object is made of. Scaling an object, changing its size, does not change its matter. Two pieces of the same quality steel, one twice as big as the other, both have the same density. The bigger piece is quite a bit heavier though.
So, in POV-Ray, if you design a lens from a glass with an ior of 1.5 and you scale it bigger, the focal distance of the lens will get longer as the ior stays the same. For light attenuation it means that an object will be "darker" after being scaled up. The light intensity decreases a certain amount per pov-unit. The object has become bigger, more pov-units, so more light is faded. The fade_distance, fade_power themselves have not been changed.
The same applies to media. Imagine media as a density of particles, you specify 100 particles per cubic pov-unit. If we scale a 1 cubic pov-unit object to be twice as big in every direction, we will have a total of 800 particles in the object. The object will look different, as we have more particles to look through. Yet the objects density is still 100 particles per cubic pov-unit. In media this "particle density" is set by the color after emission, absorption, or in the scattering statement
#version 3.5;
global_settings {assumed_gamma 1.0}
camera {location <0, 0,-12.0> look_at 0 angle 30 }
#declare Container_T= texture {
   pigment {rgbt <1,1,1,1>}
   finish {ambient 0 diffuse 0}
#declare Scale=2;
box {                  //The reference
   <-1,-1,0>,<1,1,.3>
   hollow
   texture {Container_T}
   interior {
      media {
         intervals 1
         samples 1,1
         emission 1
   translate <-2.1,0,0>
box {                  //Object scaled twice as big
   <-1,-1,0>,<1,1,.3>  //looks different but same
   hollow                          //particle density
   interior {
      media {
         intervals 1
         samples 1,1
         emission 1
   scale Scale
   translate<0,0,12>
   <-1,-1,0>,<1,1,.3>  //looks the same but particle
   hollow                          //density scaled down
   interior {
      media {
         intervals 1
         samples 1,1
         emission 1/Scale
   scale Scale
   translate<0,0,12>
   translate<4.2,0,0>
The third object in the scene above, shows what to do, if you want to scale the object and want it to keep the same look as before. The interior feature has to be divided by the same amount, that the object was scaled by. This is only possible when the object is scaled uniform.
In general, the correct approach is to scale the media density proportionally to the change in container volume. For non-uniform scaling to get an unambiguous result, that can be explained in physical terms, we need to do:
Density*sqrt(3)/vlength(Scale)
where Density is your original media density and Scale is the scaling vector applied to the container.
Note: the density modifiers inside the density{} statement are scaled along with the object.
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
